Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Brand new Tornado s30 starting help!
Reply
Old 12-29-2011, 10:58 PM
rchobbyunlimited
rchobbyunlimited's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Brand new Tornado s30 starting help!
ORIGINAL: Dads like rc too
ORIGINAL: Zlash03
Also, get a good fail safe and make sure it's set up correctly. Thatshould stop those problems.
I know everybody feels very strongly about this subject but I hate fail safes. My reasoning is if your battery connections jar loose which has happend to me several times, the fail safe is done. A good example of this would be after watching your truck cartwheel out of control, it loses it's battery connection "and fail safe" rolls back over full throttle and takes off. I like the old carb spring method myself, and with the distance you can run on these radios today, signal loss shouldn't be a factor. To me the spring works for a complete battery loss or just a weak battery condition.
Yes very ture dad also if the servo goes out the fail safe does you no good also the servo goes out with the wide open throttle the fail safe is no good to you and it runs wide open until it hits something or some one very hard the spring will eliminate all of that.
rchobbyunlimited is offline
Old 12-30-2011, 12:11 PM
Zlash03
Zlash03's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good news! I got it to run today and yesterday. I started to drive it a little while ago and man is it fast. Its so cool to drift around different things in damp grass then just take off from it. But the last, and hopefully FINAL problem is that when I go full throttle it cuts out. Like its not getting enough fuel or something. Ive adjusted every screw except for the throttle trim because I see no reason for it. It idles perfect without turning the wheels at all.
Zlash03 is offline
Old 12-31-2011, 10:02 AM
Dads like rc too
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Zlash03
Good news! I got it to run today and yesterday. I started to drive it a little while ago and man is it fast. Its so cool to drift arounddifferent things in damp grass then just take off from it. But the last, and hopefully FINAL problem is that when I go full throttle it cuts out. Like its not getting enough fuel or something. Ive adjusted every screw except for the throttle trim because I see no reason for it. It idles perfect without turning the wheels at all.
slow down Zlasher, if it's this fast just after break in your probably runnig too lean on your high speed needle. This will cause it to run flat on it's face at wide open throttle because the engine is not getting enough fuel at high rpm. If it bogs down when running wide open and you can recover by letting off the throttle you need to back out your high speed. Remember especially where you are with the cold temp it's going to be lean to begin with.
Dads like rc too is offline
Contact Us Archive Advertising Cookie Policy
