Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
new owner of a volcano pro
Old 01-05-2012, 07:32 PM
bdyman
Default RE: new owner of a volcano pro
so looks like i should have the parts this weekend,  one question what is the max nimh battery i can run in the volcano
 can i go up to 5000  or is the max 3500
Old 01-06-2012, 07:35 PM
bdyman
ok well i got the radio system and it work awesome,  but im still having the issue, battery is fully charged,  i pull full throttle i can see the esc has a red light beneath it,  and then its switching to green when im full throttle,  its still jerky, still hesitates,    im starting to get frustrated and almost readt to return the truck
     or im almost ready to just replcae with a totaly different brushless system , im at a loss on what to do
Old 01-06-2012, 07:43 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
try testing the throttle responce with the servo unplugged from the reciever.
and i assume you re-calibrated the esc to your new spektrum radio?
I have had a servo go bad before, and it effected throttle...made it glitchy.
If the truck isnt that old, then redcat should replace the ESC for you.
Or you can find the ezrun 35amp esc for around $40 new.
Better yet, upgrade to a ezrun 60amp...or even a traxxas vxl ESC if you can spare the cash.
on the battery, the # 3500 or 5000 refers to the capacity of the battery...not the voltage. so a 5000mah pack will get you longer runtimes then a 3500mah.
so you can run anything you want, a 2000mah or a 6000mah(yes the make them that high.) it makes no difference to the ESC.
also, the ESC can handle a 8.4v 7 cell nimh pack...which will get you performance similar to using a 2s lipo pack.
Old 01-06-2012, 07:59 PM
bdyman
well i did the procedure you posted a while back in this thread   if i did the re calibration wrong then how do it re calibrate it??
 the battery question now im good on i tried fitting my 7 cell packs from my old emaxx but they didnt fit   so ill look for 6 cell batteries
 and for 40 bucks for a different esc  why not spend a tad bit more and get something that i know will not have any issues
 im getting frustrated all i want to do is charge the battery and go         i never had this problem with my emaxx`s and my ken block car
Old 01-08-2012, 06:42 PM
bdyman
well this is what im noticing.......................when the battery is fully charged it works fine, when the battery is draining is when im having a issue
 so i bough the program card tonight, and am going to buy a bigger stronger battery the duratrax 6 cell 7.2 5000 nimh
   if the tuning of the esc dont work and rebinding and re calibrating dont work again   then i will replace the esc
 when i get home tonight  ill post pics of the new radio and  i re adjusted the suspension for a lower stance
Old 01-09-2012, 11:16 AM
  #31
316duke
Have you tried LVC off mine was set at 2.8 from factory and did the same thing
Old 01-09-2012, 11:18 AM
  #32
316duke
Also if you really want to wake your truck up try a 2s lipo battery wow does it wake these things up stupid fast even once i do the 12v fan change on mine ill try a 3s lipo
Old 01-09-2012, 05:58 PM
  #33
bdyman
well i just bought the program card last night and its coming from hong kong, so im sure its gonna be a while before i can tune the esc,  as far as the lipo battery goes im all set up for nimh use,      i know the use of lipo batteries are the way to go  but i just cant do lipo right now
here are some pics
Old 01-09-2012, 06:01 PM
  #34
bdyman
i almost forgot,  i have batteries left over from my emaxx,  the size is 7 cell, 8.4 5000 nimh,    can i use them ???
Old 01-09-2012, 06:52 PM
  #35
316duke
The manual says something about upgrading to a 12v fan on speedcontrol before using a battery bigger then 7.4 so i asked my dealer and he said i cold use the 11.1 lipo with bigger fan but im gonna try my 8.4 traxxas batts just how she sits
Old 01-09-2012, 07:19 PM
  #36
bdyman
well my volcano is the brushless, and it has a cooling fan      i already fit the 7 call and you have to remove one of the battery posts for it to fit
   and it doesnt really affect the way the truck sits,  just a bit heavier,  so ya come back  in here and tell if it works
Old 01-09-2012, 07:24 PM
  #37
ORIGINAL: bdyman
might have to mod the battery tray...i assume they are 7cell long packs? They should fit, as the battery tray is a bit long. If they are hump packs, you will have to use some velcro or something else to hold the batts in.
either way you can use 7cell nimh packs on the volcano.
Old 01-09-2012, 07:29 PM
  #38
316duke
i have the same truck that you have the fan that comes on the speedcontrol is only 5v and they say not to run it with anymore then 7.4v but i figure wth its only 8.4 and i have hump packs and velco raparound strap to hold the batt in
Old 01-09-2012, 07:32 PM
  #39
ORIGINAL: 316duke
the fan is safe to run with 6-7cell nimh or 2s lipo. remember, a 2s lipo will have 8.4v when fully charged.
You only have to change the fan setup to run over 7cell nimh or to run a 3s lipo.
Old 01-09-2012, 08:32 PM
  #40
bdyman
ahhhh ok cool,  so now i guess i need to find some plugs,   traxxas to bananna   anyone know where i can find them
again thanks to nitro sport for all your help,  im new to redcat products   so i appreciate all the help
Old 01-10-2012, 05:11 AM
  #41
316duke
I ordered a couple of these http://www.ebay.com /itm/180725242301?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
Old 01-10-2012, 04:42 PM
  #42
bdyman
your link is broken.......
Old 01-10-2012, 06:13 PM
  #43
316duke
http://www.ebay.com/itm/180725242301?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649 Copy and paste in browser
Old 01-10-2012, 08:03 PM
  #44
bdyman
it worked thanks,  gonna order and see what happens when i hook up the batteries
Old 01-11-2012, 05:57 PM
  #45
bdyman
all parts are ordered  just have to wait and see what happens
Old 01-17-2012, 06:18 PM
  #46
bdyman
ok guys, i got the parts batteries are charging,  the program card works pretty good  but it only goes to the 5th setting when it has 12 setting
  ill come back and post results i hope the tuning of the esc works if not i dont know what else to do
Old 01-17-2012, 08:21 PM
  #47
bdyman
ok here is the update
  the 8.4 4600 nimh battery does not work, and it fried the esc, i tuned the esc per the instructions, let everything cool down  and it still fired the esc
   so guess i have to look for a new esc and or complete brushless system
Old 01-18-2012, 11:43 AM
  #48
316duke
I would get ahold of redcat or the dealer you got it from and have them replace it being it is rated for 6-9 cells NiMH and 2-3S Lipo
Old 01-18-2012, 04:22 PM
  #49
bdyman
well i dont want their elcetronice in my truck,  ill buy a complete new system, either a traxxas brushless or duratrax,  or whatever i find  just not gonna go with red cats stuff      im pretty disgusted at this point too,   i have had the truck out for a total of 3 times and all the other times im working on it
    fixing the steering, or the radio isnt working,  or re doing gear lash, and then spent 20 bucks in parts only to find out that the esc burns up!!!   so now im stuck with a program casrd that in never gonna use again!!!     just truely disappointed
