high idle.....reving without throttle
hey guys my volcano is reving when i start it up. i took the air filter off to see where the idle screw was and the carb is open about 1mm. i cant figure this out.
i tried the trim on the controler but that didnt work i tried playing with the idle screw but to no avail
RE: high idle.....reving without throttle
Maybe your throttle linkages need adjusting....
And ive noticed on my redcat tornado that if i power on receiver before transmitter the servo slowly creeps all the way to full throttle.
Be sure to power transmitter first then receiver.
FrostY
power on the car, and then check the carb gap. if the linkage isnt set right, it may not be allowing the carb to close completly.
also, it wont hurt to try and close the gap more. If the temps are cold, it will take less air for the motor to idle.
