caldera 10e up grade motor
i got a extra caldera truck to play with and got a 100amp esc whats the biggest motor i can run in this truck just whant to make this thing shred.
RE: caldera 10e up grade motor
any 540 size can motor will fit.
You would have to modify the chassis some to fit a 550 size can motor.
If you want to be able to use the stock pinion(which I would) then you want a 540 size motor with 3mm shaft.
The traxxas VXL motor has a bit more RPMs and more torque than the stock motor and will bolt right in. I have installed that motor on a volcano.
Is the ESC rated for 3 or 4s?
NC
Which VXL system are you referring to? Also, I noticed that the VXL Esc doesn't have a cooling fan, should one be installed? Thanks.
ORIGINAL: nitrosportsandrunner
ORIGINAL: jbain2
The ESC doesnt come stock with a fan, but its not needed unless you want to run a 3s lipo.
NC
The VXL ESC has the proprietary Traxxas connectors. I have all banana plugs on my batteries. Am I better off running an adapter or converting the ESC battery connector to banana plugs or vice versa, converting the batteries to the Traxxas connectors if I upgrade?
NC
So I installed the Traxxas VXL system in my Caldera as well as a new Traxxas servo. The install was pretty easy. The biggest challenge is finding space for everything. The Traxxas ESC is larger and takes up a bit more space. I have it mounted with plastic superlock which I got from Radio Shack. I had to mount the reciever on top of the center frame. I wanted to get everything in and test it out. Everything is functioning well. Haven't had a chance to really take it out and put it to a good test. The ESC is less programmable than the stock one. The other modification that I had to make was to convert the ESC battery connectors to bannana plugs from the Traxxas style. Overall, pretty easy install to do.
ORIGINAL: jbain2
Im not saying the caldera wont handle the extra power, just keep in mind that since you have more power you will want to ease on the throttle a bit and not just peg it from a standstill.
another idea is to switch to the traxxas radio...which has a 70/30 throttle setting. that makes it much easier to control how much throttle you are giving it.
Traxxas has NEVER cared about making their ESC's small. most other companies do try to keepem small. but the xl-1/ xl-5 and vxl esc's are all fairly big.
NC
Thanks for the tip. I figured that as I couldn't program the ESC I would be stuck with the Traxxas settings regarding throttle, punch and brake. I know that there are 3 modes that can be programmed, but none of them controls the above factors.
