If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    Mar 2012
    brampton, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    just a quick question
    Hey guys so i have a quick question, when i block my exhaust to shut off my buggy (tornado S30) it just keeps on running lol car runs great and i love it but im assuming i have a leak somewhere? and im having trouble getting the engine primed when i block the exhaust aswell
    Hurricane XTE, Blackout XTE Pro
  2. #2
    bigblueford's Avatar
    Join Date
    Oct 2011
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: just a quick question
    I agree, does sounds like you've got a leak. First place I would check would be the little blue rubber coupling between the exhaust header and muffler. It shouldn't have any holes or tears in it. It should two tie-wraps, one to clampit to the header and one to clamp it to the muffler.
    Also check to make sure the header flange screws are tighten down.
    Redcat Caldera 10e MT
    Redcat Twister XTG Pro ST
    Venom Gambler SC
    Traxxas Slash 2WD
    Redcat Rockslide RS-10
  3. #3
    Join Date
    Mar 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hey well i know its not that rubber coupling cuz i changed it the other day for that exact reason lol had a tear in it :P
    but the header flange screws? im not exactly sure what those are? ive only been in this hobby a year but im obsessed lol getting my next RC this monday also could a bad manifold gasket be the cause aswell?
  4. #4
    Join Date
    Oct 2011
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There are two small screws that attached the exhaust header to the engine block, your manifold gasket goes between the header manifold and the engine block, so the two screws I'm talking about also hold the manifold gasket in place.
    Venom Gambler SC
    Traxxas Slash 2WD
  5. #5
    Join Date
    Mar 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ahhh ok i see what your talking about, yess i know those screws i tightned them myself a week ago but i think i did it too much and might have wrecket that gasket, could that be my problem? also missing one screw from my pullstart must have lost it bashing and now theres a small opening
  6. #6
    Join Date
    Oct 2011
    Muscatine, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Missing pullstart screw won't cause the leak, but should be replaced. Sounds like maybe you should retighten all the nuts and bolts. Get yourself some blue locktite and use it on the screws to help hold them tight for a longer period time. Go thru the entire car and remove one screw at a time, put blue locktitre on it, and reinstall snuggly. Be careful not to over tighten and strip out the hole.
    Remove the muffler, hold your finger over the exhuast pipe, and blow into the end with the rubber coupler. It should not leak air.
    Venom Gambler SC
    Traxxas Slash 2WD
  7. #7
    Join Date
    Mar 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for your help
    ill do everything you just said and let you know!
  8. #8
    Join Date
    Mar 2012
    washington, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    check for a air leak around the pinch bolt that holds the carb on i beat my self to death for three weeks with a redcat caldera that was leaking air
  9. #9
    Join Date
    Mar 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for all your help guys! i found the leak the gasket from the engines exhaust port to the manifold was pretty much disintegrated :P i changed it and everythings good she runs like a dream
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
