Steering knuckle.. broken D/S. Noob needs help
Hey guys, Im def new when it comes to working on my Earthquke 8E. Im having a problem. While I was down range I drove my earthquake 8e into a hesco wall and broke off my front drive shaft and a few other things. My problem is that im having here is that I cant seem to figure out why to take out my broken Drive shaft out of my steering knuckle.. here my problem. Someone please help me out. Im feeling pretty stupid and im sure its damn easy to fix.
" alt="" />
" alt="" />
IA
RE: Steering knuckle.. broken D/S. Noob needs help
That axle stub just slides in to the bearings and then a pin slides through the axle shaft. It's probably binding so you'll need to use a little force. I would start by resting the surface toward the camera in that pic over an open vice or between a couple 2x4s or something and rapping on the end of the axle stub with a hammer.
IA
ORIGINAL: nitrosportsandrunner
but 1st remove the wheel hex and drive pin on the other side.
