Long Body Posts for Caldera's
Hi all,
When I first bought my Caldera SC 10E Ilooked through a lot of other Redcat manuals to see what parts were common between models. I'm looking for longer body posts, and I'm 99% sure I've seen them before... but can't find them now. The stock ones are BS801-008:
The shock towers these bolt to are common across many models (even some of the 1/6th scales). Does anyone know the part number for the longer mounts, or if they even exist?
Thanks!
Thanks!
IA
RE: Long Body Posts for Caldera's
I don't think there is a part with longer posts. The Caldera truck, Earthquake and Aftershock all use the posts you show, and without looking I'm assuming the 1/6 scale trucks do, too. The Backdraft uses a single post at each end which is also short.
Kurt at URCHobby.com has these i used...
http://www.urchobby.com/proddetail.php?prod=904-016
