Fuel pushing out of carb
So when priming the engine on my EQ 3.5 it works fine
but about half way through my tank, it was idling as i was talking to someone,
i noticed it reving a bit then stop and it kept doing it, i took the cover off and noticed fuel flow was slow, i turned off the car, and when i tried to start it i would prime and fuel would push back, i also noticed a hissing sound when trying to prime and when i took my finger off the exhaust the fuel would push back more, i took my exhaust line off blocked the exhaust and blew in, and i heard the hissing, any ideas guys?
any help would be appreciated thanks!
RE: Fuel pushing out of carb
I think that might be it but im not sure, the temp gun i have is reading 195F-200F unless its broken and giving wrong readings?
ORIGINAL: nitrosteve22
running to hot?
running to hot?
1st make sure it didnt just flood really bad.
either let it sit overnight and try again, or turn it over with the glow plug out and holdint the truck at an angle so that fuel can drain from the base and the muffler.
Thanks everyone for your help, im going to try it might be too hot simply a tuning issue, it does sound like its running a little lean ill work with it, also anyone know how to fix the air bubble problem? the earthquake seems to always get bubbles in the fuel lines causing it to stutter when the tank is near empty, aparently im not the only EQ 3.5 owner to experiance this lol
