Volcano Epx Pro Wheel/Tire Options?
Hey Guys, Well, My tires on my epx pro are about worn out already.. So, I've been thinking about my options. First, Has anyone had any luck running 1/8th Scale wheels & tires? Just curious if has any major drawbacks? It would be nice to have somewhat bigger tires on it. I like the stock wheels and tires, but the tires arent as aggressive as I'd like them to be. But then again I drive mostly on asphault. And lastly, Where is the best place online to buy tires? Not looking to get real expensive ones as I wore these stock ones out in less than a month..
Thanks Alot,
AJ
Thanks Alot,
AJ
RE: Volcano Epx Pro Wheel/Tire Options?
1st, tires just aint cheap.
plan to spend $30-$50 on a full set of wheels and tires.
Second, 1/8 scale tires wont work, since their wheels use 17mm hex.
The epx pro's use 12mm hex (as do most 1/10 scale models)
I have run a set of traxxas stampede (rear) wheels with proline masher 2000's tires.
Traxxas stampede talon work as well (again, rear tires all the way around)
Oh, I thought they made adapters to go from the 12mm hex to the 17mm hex? I could very well be mistaken. So, Can i use any wheel/Tire combination as long as they are 12mm hex? 2.2's and 2.8's will work? Where do you buy your wheels/tires from nitro? Thanks man.
ORIGINAL: AL 01412
The traxxas rear wheels have a offset where the hex is closest to the inside of the rim (toward the truck) This type of offset makes certain that the wheel wont hit the wheel hub/camber link or suspension arm. 4wd models generally have larger wheel hubs than 2wd's...expecailly on the front.
There are hex adapters out there. Not sure if any of them will work on a epx model tho.
There are the wheels/tires for the earthquake 8e. These are the largest wheels with a 12mm hex I know of. Im not certain if the offset will work on a epx tho. And even if they did, a 1/10 scale truck with 1/8 scale tires would look funny IMO. It would also put more strain on the dogbones and stub axles and diffs. Not to mention, you would have to change the pinion gear (smaller) to adjust the gearing for the larger tires.
There there is the fact that much larger tires will make the truck higher and more likely to roll over in a turn.
The stampede talon tires are a bit taller (i think) than the stock epx pro ones. The masher 2000's on 2.2 wheels were a hair taller.
I buy my wheels/tires off ebay. Alittle searching on ebay usually will find you the best price.
check this vid, it explains offset. You want a wheel with as much offset as possible...to be certain it will work on the epx.
[youtube]http://www.youtube.com/watch?v=rdaBwBw_Jy0[/youtube]
Ok nitro, I have been searching on ebay for Traxxas Stampede (Rear) tires, And i like them alot. As i was searching I came across these: http://www.ebay.com/itm/170799734563...84.m1423.l2649 Those look just like the stock rims, just not chrome and blue, and with different tires. Do you think those may work?
I bought Losi tire/wheel combo for my son's Caldera 10e. They're called Zombie tires. I can't post a pic right now but if you look in the Caldera thread I have a pic posted on page 7, post 175. The 4 tires came mounted on the rims for $36. Then I had to add Losi hex adapters, they use their own, it's like a 13mm for another $5.
Thanks for the reply Dad, I like your username, as I myself am also a father. Those Wheels and tires look very nice, So those will fit volcano epx pro With the losi adapters? I also have another question maybe you guys can help be with, I'd hate to start another thread for it. If I were to gear down to a 14t pinion would I be able to get the truck to wheelie? Have you guys ever messed with lower gearing on your volcano pros? I love the speed of the truck, But id also love wheelies! haha. Thanks alot for your help guys, Im sure I'll have many more questions in the future, And Im thankful you guys are so willing to help.
AJ.
AJ.
ORIGINAL: AL 01412
AJ.
AJ.
Great, Im going to look Into those wheels. Thanks. When I stiffen up the rear suspension I can almost get it to wheelie, its very close, Just need more torque. I think A 14t pinion may give me the torque I need. For 7-8 dollars I may as well buy the pinion and see what happens.
ORIGINAL: AL 01412
So I got the pinion today and went to install it but the Allen bolt on the pinion is so damn tight I stripped it out... I'm not too sure on how I'm going to get it out, probably going to have to destroy the stock pinion, hopefully not the motor too. Can anyone direct me on where to buy a new hex bolt for the pinion? because the new pinion does not come with one. thanks.
ORIGINAL: AL 01412
Thanks dads, I'm going to give that a shot later this week when my replacement grub screws come in the mail. I'll let you know how it goes. I broke a rear hub carrier last night too, but I knew that would eventually happen..
Well dad, I took your advice about the mini torch and it worked, The grub screw came right out. I have the New pinion installed, now I just have to wait for a stub axle to get here so I can drive it... i haven't driven it in a week now, and I'm starting to have withdraws.. thanks a lot!
ORIGINAL: AL 01412
Do you guys know if the front c hubs from redcat come with the screw that acts as the lower balljoint? That screw fell out last night and i cant seem to find the part number for the screw. thanks alot
ORIGINAL: AL 01412
ORIGINAL: AL 01412
thanks dad's, I do you know where I can find the screws if the new hubs don't come with them?
