Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Shockwave VX16 engine temps
Reply
Old 08-10-2013, 06:14 PM
sanjay416
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Exclamation Shockwave VX16 engine temps
I took apart the VX16 engine shortly after break-in to clean it and check it's condition. The connecting rod needed replacing, which I did, then put the engine back together. When I ran it today, (not finished tuning yet), I saw some varying temps on the cooling head. After a few hot laps, the temps in the glow plug hole and around 3 of the head bolts are around 175F, but close to the other head bolt, the temp is around 215F. Is it normal to have such a temp difference on the head?
I checked the head bolts and they were tight. Could it need a new head shim?
Hope someone can shed some light on this.
Thanks.
sanjay416 is offline
Old 08-11-2013, 08:13 AM
Dads like rc too
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How did the rod need to be replaced just after break in? As rich as break in is, if you already needed a new rod, something is wrong with your engine. Take you temps around the glow plug, should be between 220 and 250 depending on how you like to run. Taking several temp readings will give you several temps. Even within seconds the temp will drop.
Dads like rc too is offline
Old 08-11-2013, 03:53 PM
sanjay416
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I have actually run about half gallon fuel through the engine. It was not run at rich break-in settings after the break-in. Did not have a temp gun at the time, so went by pinch test for LSN, and smoke trail and water drop on cooling head to set HSN. The rod was a bit elongated at the wrist pin, so I decided to change it.
I keep the engine on a high idle after running laps to take the temps (buggy on a stand). My temp gun shows continuous temps, so within 3 seconds I have the temps across the head. Like I said, the temp around the glow plug was 175F, but I'm hesitant to lean it out any more, since the temp in one location is at 215F.
Thanks for replying.
Contact Us Archive Advertising Cookie Policy
