Tremor 1/6th Truggy Screws
I lost a screw from the bottom of the front hub carriers on the Tremor. I can't figure out which set of screws I need to buy to replace it. Help?
The parts are on the exploded diagram in the manual. The parts I can see that connect to the front hub carrier are 88021 (ball joint), 16003 (suspension hinge pin) and 16026 (diff outdrive cups). I can check my Tremor for any other screws that for some reason wouldn't be on the exploded diagram and get back with you.
