sumo rock crawler setting questions
The sumo radio has two selections for the throttle/speed. (using the select button on the radio) One is the throttle and the other is speed. Can anyone tell me what the difference is?
Also it has two or three steering controls you can set the % steering, the radius for the right turn and the left turn - using the select switch and you can adjust by the "button" above the steering control/wheel what am I adjusting with the steering control. thanks M
The Sumo radio only has settings for channel 2 reverse, dual rate and end points. The dual rate and end point should be set to max. Channel 1 has the same options. DT1 will adjust the steering trim, DT2 the throttle trim and DT4 the rear steering trim.
