Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Volcano epx brushless upgrade
Reply
Old 08-28-2014, 06:14 AM
Detrailers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Volcano epx brushless upgrade
Okay, talked into upgrading me EPX to brushless - do I want 35a or 60 an=mp and I know I want to go 4300 - but will a 9t be ok without having to change gears
this is the kit I am looking at
1 EZRUN-60A-SL1.1 Output: Continuous 60A, burst 380A.
1.2 Input: 4-9 cells NiMH/NiCd or 2-3S LiPo.
1.3 BEC: 6V/1.5A (Linear mode built-in BEC).
1.4 Resistance: 0.0007 Ohm.
1.5 Motor Supported: Sensorless Brushless Motor.
1.6 Suitable Motor:
* Note #1
With 4-6 cells NiMH/NiCd or 2S Lipo: On-Road≥5.5T, Off-Road≥8.5T;
With 6-9 cells NiMH/NiCd or 3S Lipo: On-Road≥8.5T, Off-Road≥13T;
1.7 Suitable Car: 1/12 and 1/10 on-road and off-road sport.
1.8 Size: 31.5mm(L) * 27.5mm(W) * 24mm(H).
1.9 Weight: 32g(Without wires)
* Note #1: These listed T numbers are available for 3650 sized brushless motor (Ý=36, L=50)
2 9T/3650 (4300KV) Brushless Motor2.1 KV: 4300
2.2 Diameter: 36mm
2.3 Length (Without Shaft): 50mm
2.4 Shaft Diameter: 3.17mm
2.5 Shaft Length: 15mm
2.6 Weight: 170g
3 LED Program Box3.1 Size: 88mm*58mm*14mm
3.2 Weight: 40g.
3.3 Input Voltage: 4.8-6V
(If the ESC hasnít built-in BEC, you need to use an additional battery to supply the program box).
Package Includes:1 x EZRUN-60A-SL ESC
1 x 9T/3650 (4300KV) Brushless Motor
1 x LED Program Box
100% Brand New, Hobbywing Original Product
Detrailers is offline
Old 08-28-2014, 05:26 PM
westoakmech
westoakmech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That would be a good combo, you could run 3s if you wanted. The 35a would be good with nihm, and ok with 2s lipo. The 60a would be the better, if you run nihm, or 2s lipo, pretty much no worries about ever burning up. It would be pretty bullet proof. Your stock gearing should be fine. Just use the program card, and turn the punch control up. With no slipper clutch, it will help to prevent spur gear damage. If you are running lipo, make sure to set to the correct number of cells, and low voltage protection. You should have a blast with it, with the brushless system. You might want to buy a few spur gears, My son used to shred them on a regular basis. He is 12 now, and not so bad. He has learned some throttle control.
westoakmech is offline
