If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2015
    Beloit, Wisconsin
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    $140 Volcano epx
    About a month ago I was on Craigslist and came across this Volcano that was modded.
    The guy was asking $175 but got him down to $140.
    It came with steel gears all around, CV dogbones, aluminum a-arms hubs, upper frame and rear ends along with a 5700kv Mamba Max Pro setup.
    He also gave me a new 2s and 3s lipo batteries. There was also a box of spare and original parts like 3 sets of rear end gears, spur gears, extra shocks and more.
    I bought a new body for when it's cleaned up and sitting on the RC table in the den.
    Problem is I had to put the plastic spur gear back in because the steel one kept eating pinion gears every time I run the truck.
    Yesterday I ate the steel drive gear up after half of a battery. I am starting to see what many people are saying about Redcat being, not-so-good. Anyway here is the truck.
    Click image for larger version.
ID:	2067176Click image for larger version.
ID:	2067177Click image for larger version.
ID:	2067178Click image for larger version.
ID:	2067179Click image for larger version.
ID:	2067180Click image for larger version.
ID:	2067181Click image for larger version.
ID:	2067182Click image for larger version.
ID:	2067183Click image for larger version.
ID:	2067184Click image for larger version.
ID:	2067185Click image for larger version.
ID:	2067186Click image for larger version.
  2. #2
    It looks like it's way over powered since it's eating steel gears. Maybe if all your gears were steel then the pinion gears wouldn't get recked. I think your putting too much power on the truck even the brushless version has a 3300kv motor and is only compatible with 2s. A 5700kv motor and a 3s seems like too much.
  3. #3
    Join Date
    Jan 2015
    Beloit, Wisconsin
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It had the steel spur and steel pinion gears in it, went through 2 14t pinions and 1 aluminum pinion before I put the plastic spur back in. Now it's not chewing pinions anymore.
  4. #4
    westoakmech's Avatar
    Join Date
    Jan 2012
    Woodward, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you run a steel spur, you have to run a hardened steel pinion, the brass, and aluminum, won't last a couple of minutes with that motor. That is alot of motor for a volcano, and on 3s, wow, it will be a hand full.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
