Rampage MT the Throttle servo fails
I have been through 4 throttle servos in less than 30 days, pretty much every time I run.... is their another brand available to get some usage out of my 1/5th scale?
I've had many failures and after disassembly of a servo found that the circuit board off the motor is just flopping around and breaking the power wire to the servo motor, soldering it back together and installing some foam helps
