doonrunner-no spark
most likely cause is a bad ignition coil. Unless you see damage to the plug or plug wire, the coil has gone bad.
Lucky, they are pretty cheap, one on ebay right now for under $10.
There is a wire that plugs onto the ignition coil, make sure it is there and has good connection before you buy a new coil.
