Caldera engine removal
I broke the starter string on the Caldera 3.0. I know I need to remove the engine to repair. What kind and size screw do I need to remove.
Torx, hex or Phillips and what size? Screw heads are very small and I don't want to mess them up using wrong tool
Thanks?
Thanks?
other than the throttle linkage and muffler parts, there should be 4-5 screws under the chassis that you need to remove. Id think they would be hex, but could be Philips. If hex, they could be 2, 2.5 or 3mm. If you don't have a set of hex drivers, it is time to buy a set. But you can just buy a set of hex keys from any hardware store, hex drivers are just easier to use.
It never hurts to shoot some PB blast on the screws first and let it set for a half hour before trying to remove them.
There are also "easy out" bits...cost a few bucks but will save lots of time.
Ive never bothered, but I would think hitting the screws with PB blast before trying to remove them would help lesson the chance of them stripping.
