Help! Questions on MT v3
So I am currently repairing my MTv3 and I am not sure if part # 50001N (Aluminum Chassis for V3) is flat or the front end has a slight bent upwards? Mine currently has a slight bent upwards and I am not sure if it ok. Can someone confirm if the factory one is flat or bent pls? My second question is about part # 50034,(Rear Dogbones, 133mm (2pcs). Used with all: Rampage MT, Rampage TT, and Rampage Dunerunner models). What is the equivalent of this part but for the front end of the truck? I am actually in need of the pins at the end of these dogbones. Can someone please confirm if I can only get the pin or do I need to buy the entire part and what part number please. I've looked at the schematics but the front end does not show a number.
Thanks!
Thanks!
