Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
"OFFICIAL"Redcat Racing TRUCK thread
Reply
Old 03-25-2006, 05:45 PM
  #1251
entity
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OFFICIAL Redcat Racing TRUCK thread
well i've been dealing with nitro cars and trucks for a long time.. But before there were these companies.. I made upgrades myself based on my automotive career. With the plastic o.e. exhaust. I first took it apart and removed the baffle in side.. Very simple.. Tested it and tuned for it.. Worked good. Then i enlarged the inlet side of the plastic exhuast that bolts to the head.. Tested an tuned it.. I was told and did it myself from some great rc guys that to ditch the gasket.. And i did.. I just used some sandpaper on the engine and plastic to make a very nice match.. And the last thing i did was to enlarge the exhuast hole.. With a drill.. Taking step by step to enlarge it without breaking it.. And again. Tested and tuned.. Kept seeing performance gaingin and the exahust getting louder lol.. Then i got out the dremmel to enlarge the port on the engine block to match the inlet side of the exhaust.. cost me nothing. And worked out great.
entity is offline
Old 03-25-2006, 07:01 PM
  #1252
Xeller8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A note for the unexperienced....make SURE you flush the motor out extremely well afterwards if you decide to open up the exhaust port more....you don't want any metal shavings in your crackcase!
Xeller8 is offline
Old 03-25-2006, 07:32 PM
  #1253
jcam54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man-oh-man!!
I blew it up!!!! not really
I have no clue how this happened--maybe because I bash the heck out of it--i blew up a "sliding bearing 15*10*4" (inside the rear diff, that goes around the universal joint). All gears have little to no ware on them at all, just the bearing that went. The outside ring/shell split across and caused some major drivetrain noise.
I guess this is a warning to check you bearings regularly---at least nothing else went with it!!!
Got a ? some where in earlyer post plastic gears were refered to inside the diff. was that suposed to be the center diff or front and rear diffs? because on my truck all gears inside front and rear diffs are metal...just curious.
jcam54 is offline
Old 03-25-2006, 08:54 PM
  #1254
entity
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good point exceller8 you can also put some thick grease on your bits to keep most of the shavings from going into the aluminum.. They will stick to the grease and not fall in.. Cause as you know it will travel upwards..
entity is offline
Old 03-25-2006, 09:01 PM
  #1255
entity
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
btw.. diffs are enclosed in a diff case like your front and rear diff is.. And the other gears that are exposed are your spur.. Usually plastic and large and the pinion usually connected to the bell.. Both on the Engine Peace!!!
entity is offline
Old 03-25-2006, 10:34 PM
  #1256
jcam54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I understand that I was only wondering if some of these trucks/buggies had plastic gears in the front and rear diffs, like I thought I saw someone say in a earlier post.
jcam54 is offline
Old 03-25-2006, 10:50 PM
  #1257
blackdogafd
blackdogafd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys just put up some new pictures of my Syclone, checkem out
blackdogafd is offline
Old 03-25-2006, 11:31 PM
  #1258
jcam54
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool pics keep them comin
jcam54 is offline
Old 03-25-2006, 11:41 PM
  #1259
nitrosteve22
nitrosteve22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice black dog,I like the flame style bodies,I think I might have to order one for my Tornado XP as a back up or something. Here are some pics of mine .
Anyone know what grease or oil would be good for the front and rear diff? Mine work but arent that smooth,feel kinda clickity? I got some black,thick bearing grease at work I can snag a few small cups of and pack the front and rear diff to smooth em up if ya'll think its a good idea..... ???? Clean them out good first of course.
ID:	433167   Click image for larger version
ID:	433168   Click image for larger version
nitrosteve22 is offline
Old 03-26-2006, 12:01 AM
  #1260
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks guys as soon as get my new futaba radio system in and get it back out side i'll get some outside pics of jumps or something and possibly a video. just gotta figure out how to get the video on here..
Old 03-26-2006, 12:06 AM
  #1261
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey i'm going to be getting a failsafe for my buggy too should i just get the one from futaba, since the radio system is going to all futaba parts?? and i know that it will plug in just fine
Old 03-26-2006, 12:58 AM
  #1262
nitrosteve22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure about the Futaba fail safe,I use the venom and it was well worth the $40 because you not only get a radio fail safe you get a engine temp gauge with overheat fail safe and a reciever battery voltage monitor/voltage fail safe all rolled in to one. It weights next to nothing and is super easy to setup,set and forget!
Old 03-26-2006, 01:05 AM
  #1263
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok now i can go to my LHS for this right and just ask them for the venom failsafe? or should i just get it from like tower hobbies?
Old 03-26-2006, 01:07 AM
  #1264
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey how do you guys upload a picture for the side of your post under where your name goes???
Old 03-26-2006, 01:55 AM
  #1265
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey nevermind about the picture under your name i figured it out..
but i anyone here hasnt yet here's the link to do it
http://www.rcuniverse.com/forum/m_2887496/tm.htm
Old 03-26-2006, 02:18 AM
  #1266
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys i just put up two more pics of some of my other rc's. their not much but i've enjoyed all of them at one point in time
like i said they arent much but a bunch of old new brights and some misc.. ones but had to start somewhere
ID:	433227   Click image for larger version
ID:	433228   Click image for larger version
Old 03-26-2006, 03:15 AM
  #1267
futabaed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
belive it or not nitro steve i use parklube for bmx racing on my diffs
futabaed is offline
Old 03-26-2006, 03:22 AM
  #1268
eze98032
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I there all, I have a Volcano STX and I was wondering if anybody else has had trouble controlling the temp. When I have tuned to where it will Idle and the speed is good the motor Temps out at about 320. I know that that is too hot or is it? What should it temp at. If anybody could help me that would be great.
eze
eze98032 is offline
Old 03-26-2006, 01:19 PM
  #1269
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
320 is too lean. Run it at about 240-260.
Chubbysdad is offline
Old 03-26-2006, 11:40 PM
  #1270
pom08
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok a few questions about bodies and tires.... what is the hub size on the volcano? 14mm? and also what bodies can we put on it? would any body work or would i have to modify the wheel wells and mount holes?
pom08 is offline
Old 03-26-2006, 11:53 PM
  #1271
blackdogafd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey just wanted to know what i should look for when gettin a failsafe. heard people talkin about the venom failsafe, and i was looking to see if futaba also made one as well,
now i know that the venom is like a three in one, (low batt, lose of revcieve, and temp gauge) would this one be a better choice in a failsafe? or does futaba make one cause i just ordered my new futaba radio system tonight??
Old 03-27-2006, 10:42 AM
  #1272
Xeller8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pom08...
The hex size on the Volcanos is 12mm...
As for bodies...there are several 1/10's that will fit...a few may take a little bit of modification...
Chubbysdad has a few different bodies available that wil fit the Volcano also.
Xeller8 is offline
Old 03-27-2006, 01:06 PM
  #1273
pom08
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you very much for the info.... i spoke to him about bodies already... he has the Himoto ones on his site... i'm looking for clear ones along the lines of a Hummer H1 or Ford Excursion or something like that..... i don't have a ton of money to toss at my truck to figure this stuff out, that's why i ask so many questions about what parts will fit and such. i app. all the info.
pom08 is offline
Old 03-27-2006, 01:11 PM
  #1274
entity
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah go to tower hobbies.com and take a peek of all of there 1/10th clear truck bodies.. they have what your looking for.. And not bad pricing..
entity is offline
Old 03-27-2006, 01:18 PM
  #1275
pom08
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
am i looking for 400mm in length? and also do i have to worry about width?
pom08 is offline
Reply
Display Modes
