"OFFICIAL"Redcat Racing TRUCK thread
#2726
RE: OFFICIAL Redcat Racing TRUCK thread
no, thats not it. they have the aluminum ones but they are 25 bucks. do you have the volcano manual? its listed as part #02166 and called a rear shaft holder. the ball heads go into it and shaft goes through the center and the rear upper arm also connects to it.
#2727
sorry bro, i just cant find it, i have looked everywhere, i dont even see the aluminum one, post the aluminum one you said for $25 so i know what your talking about.
#2728
ic, no not the dog bones, the stx doesnt have it. anly the ball head suspension cars have them. its similar to the rear axle mount #02013 for the tsunami but its a little different. i am trying to get a picture of it for you. thanks ehroof.
#2730
bro, i checked all the sites i know of and i dont see it, email clermontmotorsports.com, allaboutfunhobbies.com and try redcats live help on their page, i dont have the sv, sorry bro.
#2735
Hi there
Is it normal that my engine is hardly putting out blue smoke?
I run it as rich as possible, tried different fuel's and nothing seems to make it smoke.
Is there an explanation for this?
Frank
Frank
#2736
you should have some blue or white smoke, do you have a temp gun, if its running over 250, it too hot. if you dont have a temp gun do the spit test, put a little spit or water on the head, if it sizzles and evaporates almost immediately your too hot, if it evaporates in like 5 seconds your ok.
#2737
it is running around 270 but if i richen it any more, it will not run.
the truck had this problem right from the get go.
i do not know why that is.
any help is appreciated.
thanks
Frank
thanks
Frank
#2738
you may have and air leak, make sure the fuel cap is sealed, also the base of the carb. Make sure the fuel line is free by disconnecting it from the car and diconecting the pressure line from the tuned pipe, then blow in the pressure line, it should be fairly easy to blow into and should have air coming out of the carb side of the fuel line. if not check and make sure the fuel nipple is not clogged. Also make adjustments to the tuning needles in small incriments, like a 1/16 to 1/8 turn
#2739
Does anyone have any ideas to look at or check to see if all 4 wheels are spinning with the same speed or even if at all?
It really appears that the back 2 tires have all the power and the front two tires seem to only spin at a fraction of the speed of the rear ones.
I do have a Redcat Volcano and it appears it's been doing this from day one. Thanks for any advice/feedback.
#2741
sit it on a block and start it, give it a little throttle and make sure the front wheels are spinning too. dont rev it alot since you can blow the engine if there is no resistance and you rev it high. if for some reason the fronts dont seem to be moving much maybe your axle holders are loose, you may need to tighten the grub screw in them, it would be the one that goes from the front of the trans to the front diff.
#2742
Yes, I've picked it up, and looked at it while holding it in my hand (just like up on a block of wood). It does appear the rear tires rotate at a much much much faster rate than the front tires.
Possibly just tightening down the axle holders will fix this? no tinkering on the rear tires, just the front?
As always thanks for the help guys!
#2743
Hey guys, just a quick, general question here, when I clean the air filter with warm water and soap, do I need to saturate it in oil afterward and then squeeze out the excess oil? If so, what kind of oil? Thanks in advance...
#2744
dry it, and put air filter oil on it and rub it in, sometimes i will put it in a plastic bag and kneed it around and work the oil in. then install it into the holder, dont oversaturate the filter, put enough to work into the whole filter. OHH, air fitler oil, your hobby or auto shop will have it.
#2747
I'm sittin here at work, and I can't wait to get home and run it. I'm planning on building a ramp for it today and maybe taking the car to some baseball fields near my house. I can't wait to get off work! haha
#2748
lol, i know what you mean, today is my birthday, i am waiting for my kids to get home so i can open my presents, i am pretty sure one is a tremor car!!!!! I left the jobsite early today, figured what the heck.
#2749
Haha, well happy birthday my friend!!! Those little Tremors look like a lot of fun! Tell me what you think of em... well, that is IF you get one...
#2750
thanks, i have the truck and truggy and i love them, alot of fun and suprisingly fast for their size. I have a video of them. i am pretty sure its a the car too, lol, i will let you guys know with a post.
http://s163.photobucket.com/albums/t...rsinstreet.flv
