"OFFICIAL"Redcat Racing 1/10th BUGGY
#553
WA
RE: "OFFICIAL"Redcat Racing 1/10th BUGGY
oh not mine, i can start my car with it like twice then its dead cause i dont charge it every time after i use it i thought it would be good for like a week even if i used it to start my car like 10 times or something but guess i'm wrong
#554
OH
http://www2.towerhobbies.com/cgi-bin...&I=LXMN95&P=ML check that sucker out. 5,000 mah!!
#556
WA
if u dont charge them for the full 14 hours they wont last very long. i dont like the hot shot one. the one i had fell apart and there really expensive you can get one that excepts duracell bateries and is aluminum and has a batery meter for that much.
#557
OH
LOL yup, had it for over a month now
BTW I've had a hot shot for YEARS now, and it's just now starting to not hold a charge. I've never had a glow plug ignitor fall apart on me...that's weird.
you drop yours a lot? you're supposed to bash your CAR not your glow plug ignitor
#561
Haha the battery fell off of my glow plug charger too man. Completely sucks. I ended up glueing it all back together. I guess It could be worse. I could have stripped a gear.
#562
well, the one that comes with the starter kit is just some cheap shrink tube holding the battery on....How long do the batteries last in the non-rechargables...I was gonna get one, but thought I'd spend too much on batteries.
#563
WA
they last just as long as the rechargables and u dont gotta wait for them to charge when there dead, and propper i DO have stripped gears i stripped the spur gear in the tranny, dose anyone no of any steel gears that might work?
#564
Ah, I think i'd rather have 2 rechargables...if they don't last any longer, I think I'd be spending a lot of dough on the batteries...
#566
WA
heres some pic of my exhaust set up, holy crap with that header the truck is TOTALY different! waaay more power! and you can see my new tiger drive system. and i wanted to ask everyones opinon on something; do u think this, http://www.redcatracing.com/itemdeta...?partno=02115B would look good on my truck instead of what i got? tell me what you think.
#567
Nah, i'd stick with the purple. It matches better.
That thing is a beast man. Nice work.
Just curious, how much heavier is it now? And is the drivetrain holding up with all that extra weight?
#568
WA
yeah mabey your right but i wish the whole thing was blue lol, it holds up great its insane as son as i puy that header pn is had awesome acceleration, and way better to speed, and its holding up perfect, after a half hour in 105 degree heat at mostly full speed the motor temp is about 180 degrees!
#571
WA
well i took my little buggy to the local rc track and i'm proud to say it was fun and exciting and quite irriating and i must say i was probably putting around the track at about 2mph lol it survived all the jumps the had there about 5-6 i think and they were all pretty good sized anywhere from 4-10inches high i think and luckily nothing broke or bent or anything it even with stood about 3flips and my dad smacking it into the concrete wall around the track i was like here dad wanna drive it since u helped buy and he was like not really but he did and i dont even think he made it 15mins before he smacked the wall and it started making a loud noise and i was oh god *** did u do to it now your done, shut it off and the exhaust pipe had popped loose and that happend about 5-6 times over a half hour and i finally got frustrated and said forget it i'm done so now i think i am gonna try and build an rc track in the back yard, but ya i was impressed nothing flipped and granted i didnt go at any of the jumps full throttle but with some of the posts i had read i was kinda worried about bending or breaking something, and i never changed out any of the shocks or changed the shock oil it is all still stock.
#572
NH
HI ALL
I need some help here.
When i prime the engine...i notice fuel drip down from near the engine where the flywheel is mounted. This leak is pretty obvious and i am just not able to get my engine to start. Once more issue is..if at all my engine starts..when i open the fuel tank , it just dies.
Whats goin on here.? Has any one faced this issue or tried to seal it ?. Any pcitures or guidelines to open from this end .
Thank you
Thank you
#573
CA
ORIGINAL: lucasdon17
HI ALL
Thank you
HI ALL
Thank you
Someone correct me here if I'm wrong but... seems your engine bearing is no good. I don't think you
can seal it. Only option is to replace the bearing or get enother engine.
Mark
#574
TN
If I'm hearing you right, you said when you open the fuel tank, it dies? It should. If you open the fuel tank, it releases the pressure that sends the fuel to the carb. The tank has to be sealed for the exhaust pressure to push the fuel to the carb. If I'm wrong about that, someone please correct me.
#575
MO
hey nitro_racer_1, i was wondering what the aluminum upper plate you have on your car is for? im guessing for reinforcment?? is it a worthy buy?
