Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Traxxas 20% nitro fuel???
Old 02-17-2006, 11:03 PM
stampede100
Default Traxxas 20% nitro fuel???
does any body know if 20% traxxas nitro fuel is the fuel to go with for a vulcano stx, if so where can i get the fuel of of the internet, it would benice if u gave me a link directly to where i can order it thanks shane
Old 02-18-2006, 12:20 AM
Xeller8
Default RE: Traxxas 20% nitro fuel???
It will work fine....just do a search for it and you will find it.
Old 02-18-2006, 12:21 AM
platinumchopper
I use 30% nitro, it seems alot sweeter... but 20% is great! just tipe in "traxxas nitro fuel" in google, there is many sites with different prices. good luck
Old 02-18-2006, 12:27 AM
jcam54
I recomend only running 20% nitro fuel
I run Power Master 20% nitro
Old 02-18-2006, 12:32 AM
platinumchopper
i was told 30% would be ok in a .18 engine by my LHS. What are the cons of 30%?
Old 02-18-2006, 12:42 AM
jcam54
From what I understand is that with the higher nitro content the motor is put under higher stress/ heat and can cause early wear out of piston and sleeve (if the motor is not "built" to run this fuel)
Most of us run only 20%----it is alot cheaper than a new motor---I'm not knocking the motors in these redcats but we have really not seen many specs on them.
I'm gonna play it on the safe side.
Old 02-18-2006, 12:46 AM
platinumchopper
yeah thats what i thought... after this bottle i will probably go back to 20%.
Old 03-01-2006, 04:05 PM
louieg3d
hey, well i use trinity 20% racing fuel and it works like a charm
Old 03-14-2006, 01:42 AM
redman1
Blue thunder 20% nitro works really well. It has a anti leaning
agent to protect your engine from harmful overleans.
Old 03-14-2006, 01:57 PM
pom08
I run 15% in both my truck and my kyosho beetle and it seams to work just fine, i don't race or really bash on them either so... haven't had a problem with it and been running it in my kyosho beetle for the last year.
Old 05-21-2008, 05:00 PM
old school modeler
higher nitro contant will increase performance, but the motor wears out a bit quicker, i use trinity 20% w/ 16% oil contant, i run superchargers and nitrous ,, and my engines are holding up fine, both are red cat engines >.18 and .28 , 15% is a great sport fuel and easy on your engine .
Old 05-21-2008, 09:28 PM
chevyderek72
chevyderek72's Avatar
traxxas fuel has too much oil, it will make your one way slip. and do the superchargers really work on these engines?
Old 05-23-2008, 12:26 PM
goldendesign04
ORIGINAL: tihstae
No. is the simple answer on both nitrous and a supercharger. Do a search an youll see a lot of information to back this up. In regards to fuel I have Odonnell 30% and traxxas 20%. They amount of additional "wear" youd get from 30 as aposed to 20 is neglible at best the same can be said for the average user in the performance area using the higher content.Sure youll see an hear a little difference but not "night and day". In short its really not worth it to bother unless your running a modified motor and you race. If not run 20% youll be just as happy with it.
-Wayne
