Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
car wont move
Reply
Old 03-15-2006, 12:44 AM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default car wont move
i just installed new gears -got a rock stuck in old one and it tore them up -put new throttle gears in and went to run but car doesnt move does that mean i tore up cluth spring or something any suggestions let me know thanks
bluecaka69 is offline
Old 03-15-2006, 11:59 AM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: car wont move
well i got it going accidentally put one way bearing wrong way but wen out to drive on nice smooth road to test it out bam tore up gears again what causes this is it the engine gear or what someone please help thanks
Old 03-15-2006, 12:05 PM
Xeller8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may not have had the mesh of the clutch gear to the drive gear set correctly...either too tight...too loose or not square.
Xeller8 is offline
Old 03-15-2006, 02:41 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how does the it sound when you are driving, are the gears loud? I am thinking the reasone people are having soo many problems with the gears on the truck is because maybe the engine mounts are moving so the engine is not square??? Also you do need to check for small rocks and pebbles in the gears, this can cause havoc too. This might explain why i am not having problems with my gears, i run my car basically on a paved street, not off road so there's not too much bumping abround and small debris to mess the gears up.
just a thought
ehroof is offline
Old 03-15-2006, 03:37 PM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they sounded normal for about 20 seconds and then it got really loud i shut her down and checked by that time it was to late gears were shredded- i didnt remove engine or even loosen screws for engine support so i thought it should still be squared- im ordering more gears and a gear set maybe gear shaft wasnt straight when i put it back into car oh well its all trial and error with nitro cars ETC.... hopefully i get it resolved cause my volcano doesnt ever compare to the tornado in terms of speed- im totally into speed and seeing how for they can fly LOL[>:]
Old 03-15-2006, 05:56 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you should be able to look at the engine and gears and see if its aligned correctly. how are the clutch bell gears linning up with the gear?
ehroof is offline
Old 03-23-2006, 02:28 PM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well the meshing of the gears appears to be good but the clutch bell sits back about 1/8 of an inch behind to rear of the throttle gearsis there a shim that you can put behind clutch bell to push it forward e to even out clutch bell with throttle gears
Old 03-23-2006, 02:55 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not really, you could put a washer inside the bell behind the screw that mounts it to the engine shaft, just make sure it not too much that the clutch shoes show. I dont really know what to say about the gear stripping unless like we said before the mesh was not correct for the engine was not square or something was stuck in the gears and stripped them out.
ehroof is offline
Reply
Display Modes
