car runs then dies
car runs then dies
i just got my tornado xp. when i finally got it to crank i would drive it forward a bout ten feet and right about then it dies. but then when i try it fires right back up and runs another ten feet. whta is happening????
RE: car runs then dies
Fire it up with the air filter off.Look at the carb and see if its open.Is it cutting off when you brake?
Or just cutting off without you doing anything?Mine did that today,so I had to richen the idle screw
just about an 1/8 of a turn in.
