If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Popper252's Avatar
    Join Date
    Mar 2006
    Tallahassee, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Help with taking apart my engine
    Hey guys, out of boredom and just curiosity I decided to rebuild my engine. Everything has been going smoothly but I got stuck with removing the fly wheel. What I think I need to do is stick a screw driver in that little hole and then use a wrench to turn the nut off but when I try it's really hard and I'm afraid I might break something. If any of you all know how to get that thing off please let me know. Any other tips about putting the thing back together and such would be greatly appreciated. Thank you.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Tornado Xp
  2. #2
    riverat1540's Avatar
    Join Date
    Mar 2006
    Algonquin, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Help with taking apart my engine
    well first off you heve to clamp the flywheel and wrench off that peice on the clutch slips around then after you remove that the fly wheel taps off. i usually just clamp the flywheel and tap the crank shaft from flywheel side but use a wooden mallet so you do marr the shaft but the flywheel is pressure fit so it will have to be tapped off. so just hold the flywheel with some big pliers while u turn that nut
    Think Big, Then Go Bigger!
    Duratrax Evader ST Pro, Blade Cp, CEN GTX 7.7
  3. #3
    Popper252's Avatar
    Join Date
    Mar 2006
    Tallahassee, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hmm, lets see i'm not quite sure i understand what you're saying. I put the wrench around the flywheel and I got the black nut loose, now the flywheel just spins freely and I can't unscrew anything anymore. Any further explanation or maybe a little clarification would be nice. Thanks again for all your help.
    Nevermind i got everything taken apart and then put back together. I'll try and start it up tomorrow and see how it sounds. I'm keeping my fingers crossed.
    Thanks for the help everyone
    Tornado Xp
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
