Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Wont hit second gear!!!
Reply
Old 04-02-2006, 12:59 AM
toastycodem
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wont hit second gear!!!
my tornado xp was fine a day ago and then today it was going and just wont hit second gear i need your guys opinon and what kind of glow plug should i buy for my tornado xp when my old one burns out. also how do i remove the glow plug just need some of your guys help thanks.
toastycodem is offline
Old 04-02-2006, 08:13 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wont hit second gear!!!
the trans on this car is not so good, it only shifts when it wants to, i have tried every adjustment there is, either it will shift tooo soon or toooo late or not at all or stay stuck in second gear. if you want to fool with it you can see it from under the car where the gears are, there is a silver gear next to the smaller black one, there are 2 holes with allen screws in them, the one offset from the center is the adjuster, clockwise makes it shift later, counter clockwise makes it shift sooner (at least in every other 2 speed car, i have 3 with 2 speed transmissions in them). You should use 90 degree adjustments at a time and try it out. Let me know what happens, maybe i just have a bad shifter, the screw was all the way in and sometimes that compresses and messes up the spring that throws the arm out, its kinda works the same way the clutches work on the engine, the faster the rotation the more the arm comes out and grabs the next gear. <--------hope this helps you out and makes sense
You need a short plug not a long one most cars use the same plug. you remove it with a glow plug wrench.
ehroof is offline
Old 04-04-2006, 04:57 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine did get stuck in second one time. It was a total pooch !! the first time it hit second , I though the car was comming apart , it was a loud bang like someone hit it with a hammer. Its been ok now , I hope I didn't just jinx it though.
AJsToyz is offline
Reply
Display Modes
