Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Throttle Pull Rod
Reply
Old 04-10-2006, 04:21 PM
JYOUNGBERG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throttle Pull Rod
I have this funny noise coming out of my throttle pull rod i think its where it hooks up to the servo if anyone knows what's up with it i would appreciate it...
I think it could be my servo...
JYOUNGBERG is offline
Old 04-10-2006, 08:09 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Throttle Pull Rod
maybe the gears are stripped inside, does it make the noise when you give it throttle or break, sounds like smething skipping??? or is it a humm, the humm is normal especially when you give it brake.
ehroof is offline
Old 04-10-2006, 11:34 PM
Popper252
Popper252's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check to make sure your glow plug isn't running too hot otherwise it may interfere with your reciever. Also check the flux capicitor, sometimes those get out of whack. But seriously... Is the noise coming from the servo itself? Maybe you have a stripped gear in the actual servo motor? Baisically what ehroof said. Let us know.
Popper252 is offline
Old 04-11-2006, 12:13 AM
JYOUNGBERG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its like the servo goes sometimes and other times i have to push it first car so i don't understand do you thing i should buy new servo or have any suggestions
Old 04-11-2006, 12:20 AM
Popper252
Popper252's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is your throttle control on your radio not set correctly? Maybe when you have it turned on the brakes are engaged and that's why you have to give it a push? In short turn the little knob on your radio that says "Th Trim" to the point where the car sits still while ideling but not too much so it'll still roll freely with out the brakes being engaged. I'm not sure if that's your problem or not but it could be a possibility.
Old 04-11-2006, 12:23 AM
Popper252
Popper252's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that I think about it, when you said your servo goes sometimes and other times you have to push it. It sounds like you have a stripped gear inside the servo. When you're pushing it what you're doing is probably turning it to where the gear in there isn't stripped and then it catches. If you're comfortable with takeing your car apart (which you should get used to) take the servo out and there are four little screws on the bottom that you have to loosen. Then take the cover off and check the little gears in there. There are a couple of them so make sure you remember the right placement so you can put it back together. Look at those wheels and see if you're missing any teeth.
Old 04-11-2006, 12:08 PM
JYOUNGBERG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what do you mean flux capacitor..
Old 04-11-2006, 12:30 PM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
he was just joking there was a thread going on about a redcat employee saying the glow plug caused the radio not to work
bluecaka69 is offline
Old 04-11-2006, 01:57 PM
JYOUNGBERG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys the gears were stripped i ordered a new one thanks alot for all your help
Old 04-11-2006, 10:03 PM
blackdogafd
blackdogafd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey dont ever hesitate to ask questions we are all here to help one another here.
blackdogafd is offline
Old 04-14-2006, 09:08 PM
JYOUNGBERG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i skipped the place where theeth are missing to get me by tell servo shows up
Old 04-14-2006, 09:13 PM
Popper252
Popper252's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haha that's kinda risky, but hey whatever you feel comfortable with
Contact Us Archive Advertising Cookie Policy
