I'm MAD AS Hell
I'm MAD AS Hell
How come no one told me that adding a header pipe will increase power by more than 30%???
I pulled a header off a OS motor put it on the 1/10 buggy and Jesus Christ it is fast now!!!
RE: I'm MAD AS Hell
Guess your happy lol. I have added them to the volcano and the heck if I see 30%. Might see a little of course because of the open design. Alot less restrictive thats for sure.
RE: I'm MAD AS Hell
This is like a 5" "U" shaped pipe off a GP2 (that i blew the engine in), it looks like frankenstien but the difference is huge.
I don't know if it's the length of the header or what but dam...
RE: I'm MAD AS Hell
hey bill if ya wanted to you could add this exhaust system to your application, its the one that i'm getting for my syclone! check it out
http://rchub.com/Merchant2/merchant....=timedspecials
you also can add any HPI header pipe for side exhaust and find your own exhaust pipe that you want
RE: I'm MAD AS Hell
Ripped from the pages of nitrorc.com
"Tuned Pipes:
So we have some unburnt air/fuel that could be used to generate power and it's going out the exhaust manifold. This is where the tuned pipe comes in. The construction of the tuned pipe works with the pressure pulses coming out of the exhaust port. The pulses resonate inside of the pipe and travel back into the manifold. The pressure pulse actually pushes the air/fuel mixture that escaped out the manifold back into the combustion chamber. This super-charges the combustion chamber and gives the 2-stroke engine its characteristic peak HP. This is the point in which the engine turns ON. You will know that you hit this point because the car will accelerate rapidly when the engine gets on the pipe. You can actually fine-tune when the engine will have this extra burst of power. The speed at which the pressure waves from the pipe synchronizes with the piston, is a function of the length from the belly of the tuned pipe (widest part) to the center of the glow plug. The longer the distance, the faster the engine will come on the pipe. If you want to delay the time when the engine hits the supercharge, then shorten the header and/or pipe. When you replace the stock header/manifold, keep in mind that there is a reason for a pipe's size and geometry. You can use this information to your advantage to strengthen your engine's power band. A bad decision in the exhaust department can actually lower engine performance. "
An extra 5" of pipe makes a BIG difference.
"Tuned Pipes:
RE: I'm MAD AS Hell
this is a similar header pipe to the one from the GP2
http://www2.towerhobbies.com/cgi-bin...&I=LXCPR9&P=FR
Can I cut off the end, JB weld a copper tube the same diameter and point it straight up instead of running accross the top like it is now?
Will the copper and JB deal OK with the temps?
RE: I'm MAD AS Hell
ORIGINAL: blackdogafd
Blackdogafd,
I don't think the muffler at the end makes a difference as I'm using the original. The length of pipe is the kicker. As i said above I'm going to frankenstien this baby out with a straight up or back exaust and tear it up!
RE: I'm MAD AS Hell
hey man i was just putting out a suggestion.. and yeah if you "were" to get a tuned pipe it will make a difference, just like adding your header pipe you have mentioned. it will give you some more power and it sound cool too
but just throwing things in the air to you guys!!!
RE: I'm MAD AS Hell
Suggestions are always welcomed
I'll clock the speed this weekend and hopefully do the "jump" sunday as well.
I have to sober up my camera guy tho
