REDCAT WHY DO THE GEARS STRIP OUT?? BIG NEWS ADDED PAGE 5!!!
#401
RE: REDCAT WHY DO THE GEARS STRIP OUT?? BIG NEWS ADDED PAGE 5!!!
i just recently purchaed aredcat tornado xp , ididnt even get the motor broke in before the gears and bell housing went out can someone tell me what to replace these with besides redcat junk . help please , i didnt even run this car 20 minutes. thanks chris
#403
MI
I thought so too? Maybe he got one just before the swap from someone's inventory?
Anyway, yes there are plenty of alternatives out there. Get a hardened steel one, check out www.clermontmotorsports.com or www.allaboutfunhobbies.com
They have the best prices, best service, and fastest shipping around!
Check this thread out for more detail/info: http://www.redcatrc.com/forum/viewto...=25&highlight=
#404
ORIGINAL: hoveyhere
http://www.clermontmotorsports.com/s...le-gear/Detail
and this hpi setup for a clutch bell:
upgrade your 2 speed clutch bell to: http://www2.towerhobbies.com/cgi-bin...4&I=LXCLR2&P=K + http://www2.towerhobbies.com/cgi-bin...4&I=LXDHM0&P=K + http://www2.towerhobbies.com/cgi-bin...4&I=LXCLR9&P=K
you may need to widdle away a little of the upper plate post so the gears clear it
upgrade to this clutch spring while you have the clutch bell off:
traxxas 4146x : http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
#407
these trucks do come with the new metal clutchbell and spur gear i just got one on ebay pretty cheap so hopefully the problems are now solved?.hope so anyway its for my ten yr olds birthday in june,looks like a pretty good truck for the money as i got it for way under half price if not 1/3rd having paid £76 for it brand new .
#409
ORIGINAL: rclynx
Its your duty to test it as many times as necessary to determine if its fixed properly
#411
is that the new 2007 model or all models as i thought the orriginal ones were not aluminium? if they were what was the problem with them.
#412
TX
All the 1/10th scale models have cast aluminum clutch bells, the 1/8th scales have machined hardened steel clutch bells. The problem with the aluminum ones is that when they get hot they warm and strip out your spur gear, the gear on the clutch bell also wears out VERY fast and will strip out your spur gears, the aluminum clutch shoes wear out the inside of the clutch bell uber fast too, clutch shoe spring is week and breaks easily.
#414
the reason it usually the out of round aluminum clutch bell (stock), you need to upgrade to an hpi setup, its all in the faq thread on top (sticky).
#418
single speed its this one http://www2.towerhobbies.com/cgi-bin...?&I=LXLST9&P=7
#419
now i am going to buy one of these cars, either the tremor or the xp.
what i think is happening is that the two speed is absent of the important slipper clutch. like all you know the slipper well, slips if there is excess torq on the drive tran. when your driving your car off road the gears are subjected to diferating pressure, this pressure is highest when jumping, accelerating or during the second gear transition. when you mix cheap plastic with no slipper and high torq you are asking for trouble.
i belive the gearbox was developed for the on road cars because the terrain is flat and is not subjected to massive load, they figured to give everybody two speed and keep the cost of desighning down.
so, i would only get the single speed tranny, just put in a spur with less teeth.
when i get a car im going to swap the spur with a traxxas (if capatible) traxxas makes a strong gear.
#422
NJ
just to clarify. The NEW single speeds are steel silver. You have to use a magnet to see for sure if you have steel or aluminum.
ORIGINAL: ehroof
if its silver, its aluminum, if its black, its steel
#424
the xl is a 1/10 buggy and it has a steel clutch bell and upgraded clutch shoes and spring, the tremor is a 1/16th, totally different.
#425
Whats up Hooked. Im sooo with you on this. I was getting ready to buy one on Friday (payday) but htis thread has me second guessing this company. If you got an answer on this situation let me know. Or anyone else to that fact.
