Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat vehicle repair/tune FAQ
Reply
Old 01-20-2008, 10:54 AM
  #1026
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat vehicle repair/tune FAQ
you should put the throttle trim at neutral (center) and put the servo arm so the throttle is 1mm open and brake is not on, then you will have some trim to work with. maybe your arm is in a bad position, reposition it.
ehroof is offline
Old 01-20-2008, 11:06 AM
  #1027
S.R.G.
S.R.G.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is centered on the controller which means nothing most of the time. I am looking at the servo arm - should it be
ID:	855813   Click image for larger version
ID:	855814   Click image for larger version
ID:	855815   Click image for larger version
S.R.G. is offline
Old 01-20-2008, 11:22 AM
  #1028
S.R.G.
S.R.G.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One more thing though - I just noticed that with the throttle trim at zero, and my carb settings, when I applied the break the carb would completely close.
Now I have screwed in the idle about half of the ay to expose about a 1 mm opening (pen head and a little bit more). Now when I have the throttle set to zero, and apply the break, it does not close the throttle. I have taken pictures of my idle setting. Maybe someone can tell me if it looks about right. It is exactly the width of a compressed air straw - sorry for the redneck measurements, but no ruler around here or a measuring tape - and just about everyone can relate to the diameter of a compressed air straw.
ID:	855829   Click image for larger version
ID:	855830   Click image for larger version
S.R.G. is offline
Old 01-20-2008, 01:37 PM
  #1029
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
by 1mm, i mean inside of the carb, inside the neck. i cant tell by those pictures.
ehroof is offline
Old 01-20-2008, 02:42 PM
  #1030
bigredtitan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how far should the carb screw be out? my volcano idles almost wide open and spit out a little fuel. sorry i am new to this. any help appreciated
bigredtitan is offline
Old 01-20-2008, 02:45 PM
  #1031
Macanan
Macanan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here you go
ID:	856062   Click image for larger version
ID:	856063   Click image for larger version
Macanan is offline
Old 01-20-2008, 03:07 PM
  #1032
S.R.G.
S.R.G.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea, I know the 1 mm inside the carb - I was just hoping that the idle screws position is possibly how it should be - as in if all the engines are the same, and the throttle is zero'ed, then the idle screw's position should be the same. I cannot get a good picture if the carb, sorry, but it looks to be 1 mm. Another thing, when the break is applied, the carb should not move, but only the breaks be applied, correct? I am asking because with this new setting which I have not tested, the 1 mm opening stays the same when brakes are applied - but with previous settings, the carb was closed and the breaks were applied.
Thanks for your help.
Quote:
ORIGINAL: ehroof
S.R.G. is offline
Old 01-20-2008, 03:13 PM
  #1033
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the carb should NOT move when hitting the brake, sounds like you have it right now.
ehroof is offline
Old 01-20-2008, 03:18 PM
  #1034
S.R.G.
S.R.G.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yea, I hope so. Before when hitting the break the carb would close and the car would die - so yea, had it all jacked up. The motor has not moved since factory default, so I have not checked the mesh. The gears look just as they did when I got it, so if the mesh was wrong, they should be worn on nicked, correct? I tried doing the mesh slightly - well getting a piece of paper in - with the muffler off, but stopped before I got something jacked up . I may go out today and run it around, but still worried about the rear shaft housing being slivered off, but it was around the outside off the metal, so should not affect the car. Now all I have to wait for is the temperature to go to at least 45, the I will be set.
S.R.G. is offline
Old 01-20-2008, 04:08 PM
  #1035
bigredtitan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks i will try that
Old 01-29-2008, 09:21 PM
  #1036
haz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes i upgraded the manifold.
haz is offline
Old 02-02-2008, 10:53 PM
  #1037
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi folks. Question for everyone. I have a Volcano SV
I took apart My Rear Lower Arm and Axle Holder. I found Brass axle BUSHINGS instead of ball bearings. Below are some pictures. From the left; the entire assembly, the axle holder, and the brass bushings/bearings.
Does someone Make BALL BEARINGS to replace these brass bushings?
If so, can someone post a p/n or a link?
ID:	868586   Click image for larger version
ID:	868587   Click image for larger version
Redharris is offline
Old 02-03-2008, 01:49 AM
  #1038
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get boca bearings bro: http://www.clermontmotorsports.com/s...ngs/Categories
ehroof is offline
Old 02-03-2008, 02:49 AM
  #1039
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are these the ones that match?
I measure 10mm x 5mm x 4mm
And 15mm x 10mm x 4mm
The number system on the Bocas are reversed, but I think these are correct.
http://www.clermontmotorsports.com/s...-5x10x4/Detail
http://www.clermontmotorsports.com/s...10x15x4/Detail
Old 02-03-2008, 10:52 AM
  #1040
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would ask dennis to just make sure but i think so.
ehroof is offline
Old 02-05-2008, 10:18 PM
  #1041
speedracer3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need help. Somebody help me please?
speedracer3 is offline
Old 02-05-2008, 10:21 PM
  #1042
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am helping you bro, answered your pm and your other thread, we will figure it out.
ehroof is offline
Old 02-05-2008, 10:46 PM
  #1043
speedracer3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Send the pm again i did not get it. And thank you for your help
Old 02-06-2008, 06:55 PM
  #1044
mrmechanic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a redcat racing tornado and i rebuilt the clutch and now it acts like its got no bearings. please reply if you know.
mrmechanic is offline
Old 02-06-2008, 06:58 PM
  #1045
mrmechanic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 02-06-2008, 07:55 PM
  #1046
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did you put it back in the same order you took it apart, if you loosed the screw and it spins feely you have to check how its was put back, you said clutch, you have to make sure the spring is connected and hasnt come undone.
ehroof is offline
Old 02-06-2008, 09:46 PM
  #1047
Shockdriver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can someone take a picture of a single speed transmission correctly put together i would appriciate it very much
Shockdriver is offline
Old 02-07-2008, 12:38 AM
  #1048
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Shockdriver
Here you go!
Old 02-07-2008, 12:42 AM
  #1049
Macanan
Macanan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats the oddest single speed I have ever seen. Whats it out of ?
Macanan is offline
Old 02-07-2008, 01:09 AM
  #1050
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Volcano SV. Whats odd about it?
Reply
Display Modes
