tornado xl 4wd
CA
RE: tornado xl 4wd
Sounds like to me he means his center drive dogbone.
if your dogbone is bent or worn out, it'll fall out. also, you may want to check where your upper deck meets the front bulkhead to make sure it's not damaged.
RE: tornado xl 4wd
the front end is brandnew i replaced all parts dogbone or the "shaft" is all brandnew brandnew chassis. it falls out just enough to bind
RE: tornado xl 4wd
maybe you lost small rubber o-rings that sit in joints. These do not allow shaft to move back and forth and even when joint screw gets a bit loose they dont pop out. I also had same problem, just cut small slice of eraser, put in both joints and check if shaft is not moving. If is is not then u can play with your toy
