Bent transmission shaft
MO
Ok so I need help, lots of help. lol My whole trans binds bad so I ordered a spur because the original was wobbling badly. Come to find out the freakin shaft was bent it self?? I have no part number and I don't want to have to buy a complete gear box just for 1 part, but if I cud just drop it in and bolt it on and it would work that would be cool too. Here is a picture Sorry I cudn't zoom the camera any closer or it would be blurry.
RE: Bent transmission shaft
Dan, I'm not sure of the part number off the top of my head, but I think I got one or two in the bunch of parts I got from Blue last week. I will check it and get back to you...
MO
Ya thats it, but how do I know that it won't be the slightest bit out of round? We cudn't tell it untill we put the shaft into a power drill and put the big gear of the spur gear set on it. Other than that I would have no problem buying it from you I just don't want ot have to send it back and then get another bad part.
MO
Ok cool, i just put the big black plastic spur gear on the end and it vibrated about 1/4th an inch side to side and was causing sever bind. I'll talk to my mom and order it after you tell me what you find.
Order p/n 08013. Or 2. This is the complete shaft and both new gears and slipper discs. I don't know how you bent that shaft! I just order these must of the time and I change everything at once. I did order some P/N 08033 gears but you need to reuse the shaft and slipper discs and spring assembly. It's a pain to replace but I've got 2 old shafts and discs so I rebuild them and have them on hand.
