oil?
RE: oil?
It's some of the oil from the fuel that is weeping around the starter shaft bushing. The oil in the Nitro fuel is used to lubricate the engine and will ooze out. Remove the pullstarter and take a look. If it's not the shaft then you may have to seal the backplate.
