HOW TO TAKE TRANNY APART.
MO
I TOOK THE SCREW ALL THE out and the spring poped out. so i think i have to take the tranny apart to get the screw and spring back in. so does anyone have the steps to take it apart? i already have the engine off. thanks
CA
RE: HOW TO TAKE TRANNY APART.
Hey Lee,
There isn't a tutorial on taking your tranny apart. It's best to just go off the picture in your manual.
If it's just the set screw and spring on the clutch then you might not have to take everything apart.
The order they go in is.... ball, spring then set screw. If you need help with adjusting the clutch to shift, see post number 20 in
the FAQ/tune/repair thread here: http://www.rcuniverse.com/forum/m_4207842/tm.htm
Hope this helps.
Mark
Hope this helps.
Mark
MO
ok ill check the manual out. also ive tried to go by the post in FAQ/repair/tune thread and my car still wont shift. maybe something is broke in the tranny? does anyone know what else might make the car not shift if the screw you ujust doesnt make it shift?
MO
i got the sping and nut back in, but should the small gear of throttle (thats what diagram calls it ) be able to spin freely if i spin it? cause it can.
ORIGINAL: leesmack
