Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Professional opions wanted
Reply
Old 11-01-2006, 07:45 PM
mam4006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Professional opions wanted
I own a Volcano STX 94108. The truck has been running great and I've learned how to tune it thanks to all of the information given in these forums. I've been running the truck every other day or so without one single problem. As I was running it today, I started loosing some braking power. I took it to the local hobby shop for what I thought would be a simple adjustment to the brakes. The truck use to have a plastic sleeve and a plastic piece that you could screw the sleeve (I'm assuming to make adjustments). The shop replaced these pieces with 2 mental nuts, opened/closed the throttle a couple of times, kept making adjustments to the new metal nuts, rolled it back/fourth across the table a couple of times and said, "that should get it"
I got the car home to test out the brake job and it went 10 feet and the clutch belt broke. I called the owner of the store and explained that my truck has been running perfectly without one problem and I just had them work on it (brake adjustment) 30 mins ago and it went 10 feet and the clutch belt brakes. They looked at it and said they wouldn't fix it because nothing they didn't could have caused this. I said that your're telling me that my truck has run perfectly prior to coming to get a brake adjustment and I get it home and run it 10 feet and it the clutch belt brakes and your telling me that is the biggest coincidence in the world!
So, I'm asking for some professional opinions on whether or not the shop could have done anything, i.e., over tighten the brakes, replace the plastic sleeves/ plastic screw with the metal nuts, or anything that could have caused this damage, or was this actually the biggest coincidence in the world?
Thank you in advance for your opinions.
mam4006 is offline
Old 11-01-2006, 08:48 PM
Popper252
Popper252's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Professional opions wanted
What are you talking about when you say clutch belt? I'm not sure what you're referring to exactly.
Popper252 is offline
Old 11-01-2006, 09:43 PM
mam4006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not sure exactly what is is either. They simply told me the problem is clutch belt broke. It's the part right in front of the gear. It's a silver part (ring) that is now loose that is right in front of the gear. Hope the picture helps but you really can't see it. It's just a silver ring that is in front of the gear in the picture.
ID:	552786   Click image for larger version
mam4006 is offline
Old 11-01-2006, 09:57 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
clutch spring?? i am suprised you were able to go a tank without changing your clutch spring. The stock spring is garbage and needs to be replaced. replace using traxxas 4146x. the shop had nothing to do with the clutch spring breaking.
ehroof is offline
Old 11-02-2006, 09:21 AM
mam4006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, and I have upgraded the spring to that Traxxas one but it's not the spring. It's the clutch belt. It's the silver metal ring right in front of the silver gear in the picture. If you took your finger and placed it right in front of the gear, you could spin the silver part.
mam4006 is offline
Old 11-02-2006, 09:23 AM
jczechjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It looks to me like he means the clutch bell. It looks broken in the photo. I do not see how messing with the brakes could have done this unless they were adjusted until they were on all of the time and it caused the clutch to engage and the buggy to sit still and melt the clutch bell.
jczechjr is offline
Old 11-02-2006, 09:40 AM
mam4006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay, I may have misunderstood, it may be the clutch bell. When I did bring it home, as soon as I would let off the gas, it would stop sharply on it's own without even having to apply the brake. I ran it a few more feet, again, it would stop sharply without even having to apply the brake, it would stop sharply. A few more feet and that's when it broke.
mam4006 is offline
Old 11-02-2006, 09:56 AM
jczechjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That does sound like what I was explaining above. The brakes were being applied all of the time. Which means that the clutch was spinning around inside the clutch bell with it stopped. It would only move when you gave it enough gas to defeat the brakes. I would say it was there fault. But I wouldn't replace it with a redcat clutch bell you need to put a HPI steel clutch bell on it. The model number is A993. Also the need to adjust the brakes so the only engage when you apply them.
jczechjr is offline
Old 11-02-2006, 09:59 AM
gundamjake
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is your clutchbell that is broken. It probably wasn't the brakes the caused it to brake. So, there are a couple of options that you have in front of you. You can get a new clutchbell from us here at Redcat. Or.... you can upgrade the clutchbell with a steel one. A good one to use would be the Heavy Duty clutchbell for the HPI Savage. It will bolt right on there and last a good long while.
gundamjake is offline
Old 11-02-2006, 10:36 AM
mam4006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gundamjake, even after reading jczechjr’s explanation, you still don’t believe that the brake job they did caused it? If the car dead stops on it’s own when I let off this gas, without even having to apply the brakes, it wouldn’t cause any damage and make the clutchbell brake?
mam4006 is offline
Old 11-02-2006, 10:49 AM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
brake adjustment has nothing to do with the clutch bell, redcats clutch bells are known to fall apart, there are several pictures somewhere on this forum of this. get the hpi clutch bell, it will also help you save on spur gears in the long run.
ehroof is offline
Reply
Display Modes
