Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Transission Issue?
Reply
Old 12-28-2006, 07:18 AM
stuber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Transission Issue?
Please help!
On my first tank of fuel the car was losing power until it finally stopped dead. After picking the Tornado up I noticed the rear drive shaft was off!
I replaced the shaft and went back to start the car. Upon starting the car will not move now! I try to roll it by hand and it just goes about 1/2 inch
and stops! Will not roll backwards either. It will idle, but when I apply throttle it just dies! Have I destroyed the transmission? Is something too
tight? Please help.
Ed
stuber is offline
Old 12-28-2006, 07:25 AM
{GBI}Harryball
{GBI}Harryball's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Transission Issue?
Sorry dude, which shaft exactly fell off, the dog bones going to the wheels or the one from the tranny to the diff?
{GBI}Harryball is offline
Old 12-28-2006, 07:32 AM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What tornado do you have? Single speed or 2 speed?
ehroof is offline
Old 12-28-2006, 11:16 AM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
either stripped gear or you lost a grub screw tha holds drive cups to diff
bluecaka69 is offline
Old 12-28-2006, 12:18 PM
stuber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, perhaps I wasn't clear. the grub screw did fall off but I got another.
I have a 2 speed.
the drive shaft that fell off was the one from the tranny to the diff.
the car starts fine but it just seems like the brakes are on, it will not move. the car will not roll forwards when the engine
is not running or running!
thanks for the help!
Ed
stuber is offline
Old 12-28-2006, 12:43 PM
zack221
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try loosening the brakes first they might have tightened up on their own.try sliding the motor over as far as you can away from the throttle gear and see if it will row dont start it like this.If it dont row after loosening the brakes and sliding the engine away from the tranny you either have messed up the differential or you got something inside the tranny thats not letting the gears move
zack221 is offline
Old 12-28-2006, 01:02 PM
bluecaka69
bluecaka69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I read somewere that someone got a little rock stuck i the brake pad maybe you did that also
or your engine screws came loose and motor shifted causing gear mesh to be way to tight check these hope you get it worked out
Old 12-28-2006, 05:25 PM
dclintonh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i had the same problem.
loosened the brakes and its worked fine ever since.
i have no idea what happened. but i did use some intake cleaner the day before the problem.
dont loosen them up to much, make sure it stops when u use the brakes though.
my $0.02
dclintonh is offline
Old 12-29-2006, 09:15 AM
mozzzy_2000
mozzzy_2000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check your brakes. check your clutch mesh and check to see if any of the diffs are locked up.
mozzzy_2000 is offline
Reply
Display Modes
