Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Nitro Engine Troubleshooting and Tuning
Reply
Old 02-29-2008, 02:24 AM
garyedwards
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nitro Engine Troubleshooting and Tuning
one question should u start the car with the wheels on the groung or off.
garyedwards is offline
Old 02-29-2008, 02:35 AM
webbl19
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you are new do it off the ground until you get a feel for how it starts if you are using your throttle trim and stuff sometimes they like to start up and take off if it is on the ground.
webbl19 is offline
Old 04-03-2008, 07:12 PM
radford512
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi i have a shockwave and it is all wheel drive and the front wheels only spin and the rear does not can you help?
radford512 is offline
Old 04-03-2008, 07:59 PM
pede_187
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check the rear dogbones, and rear diff first
pede_187 is offline
Old 04-03-2008, 08:21 PM
Lordmik
Lordmik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CHeck the grub screw that holds the drive cup to the center trans. make sure the driveshaft that turns the rear turns with the spur. If not, it's probably that grub screw backed out.
Lordmik is offline
Old 11-18-2008, 02:57 PM
  #31
JEF1971
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IM WORKING ON A SHOCKWAVE I PUT A FEW DROPS OF FUEL IN THE CARB AND THE CAR STARTS IMMEDIATELY BUT CUTS OFF WHEN THIS FUEL BURNS OFF-IT DOES NOT PULL FUEL FROM THE TANK. IF I TAKE THE FUEL LINE LOOSE FROM THE CARB AND START THE CAR, IT PUMPS FUEL THRU THE LINES...PLEASE HELP
JEF1971 is offline
Old 11-18-2008, 10:10 PM
  #32
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok what you need to do is put the fuel line to the carb on, then take off the fuel line that goes to the pipe and blow in it, it will push fuel to the carb, right when fuel hits the carb stop blowing. then put a couple drops of fuel in the carb. then make sure your settings on your carb are fine. put the hsn at 2.5 turns out, and the lsn flush with the collar. those are base settings so tune from there. then it should start up. if it doesnt start up i hold the car down with the radio, and pull the throttle, put the glow ignitor on, and then pull start it, it gets more fuel to the carb and that way it will start if its being stubborn
chevyderek72 is offline
Old 11-29-2008, 04:58 PM
  #33
Rene1977
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Need some help here- my pullstarted won't pull and the clutch bell won't turn, it's been like this for a while and I know it's not flooded. Help please!
Rene1977 is offline
Old 12-13-2008, 11:54 PM
  #34
ohhalecks83
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wen i open the throotle more than half way it bogs out. but less than that it doesnt. whts wrong. any help
ohhalecks83 is offline
Old 12-30-2008, 05:40 PM
  #35
benandedie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a volcano truck and it was not tuned well, I began to tune according to instructions and no when I try to pull start it is very hard! I need help so that I dont throw it.
benandedie is offline
Old 12-30-2008, 06:49 PM
  #36
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its probably hydro locked, aka flooded. take the glow plug out and flip it and pull the cord.
Old 01-10-2009, 10:40 AM
  #37
AZMIN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys. I'm newbie here and have some problem tuning my buggy engine.I know some basic stuff (high needle - clockwise will lean and vice versa.....idle needle- clockwise will high idling and vice versa) but my current problem is:
1) What is the function of low needle?
2) My engine is one gallon old and idling fine (it was broke in by LHS). However, when I give some throttle...my buggy runs smoothly and when I give full throttle for the first time...it runs nicely..BUT when I give another full throttle....the engine sounds like going to die/stall and when I continue giving full throttle..it will die/stall. Whats should I do?
Hope to get some help here.Thanks
P/s: Anyone knows any link/website that teaches how to troubleshooting/tuning nitro engine comprehensively???..
AZMIN is offline
Old 01-10-2009, 04:30 PM
  #38
perhamrocks
perhamrocks's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1) the low speed needle determines how rich or lean it is between 0 and 50% throttle so leaner equals more acceleration and also will stay idling longer.
the best way to check the low speed needle is to get your car running rund the car in a circle or two, then bring it back to you and pinch the fuel line. if it takes longer than 5 seconds to died then it's too rich, if it takes less then 3 seconds to die then it is too lean.
2)sounds like your high speed needle is too lean and it's getting starved of gas when your going full throttle. set it back to factory settings, which is all the way in, but don't tighten it!!!!!, then 2 1/2 turns out. Then re- tune it.
3)the redcat site has something about tuning but also take a look at this
[link=http://www.youtube.com/watch?v=pEGjExP9GkM&feature=channel_page]http://www.youtube.com/watch?v=pEGjExP9GkM&feature=channel_page[/link]
edit: also make sure that your engine doesn't go over 260 degrees fahrenheit
perhamrocks is offline
Old 01-11-2009, 03:13 AM
  #39
AZMIN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks man..will try to do as what you suggest..cheers
AZMIN is offline
Old 01-11-2009, 04:56 PM
  #40
jambafromhell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Help!, Does anybody know that stock settings for the vx.18 engine on the tornadobb!?
jambafromhell is offline
Old 01-11-2009, 06:02 PM
  #41
codokas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2 1/2 out from closed on high
flush with collar on the low
DOUG
ORIGINAL: jambafromhell
codokas is offline
Old 01-11-2009, 08:22 PM
  #42
jambafromhell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dude thanks for the quick response, u are a life saver, i think i would have ****ed up my engine with out the stock settings
Old 01-25-2009, 09:47 PM
  #43
AZMIN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guyss..another help needed!!!
When I give full throttle and straight away release back to neutral position , the engine will scream BUT hang for like 2 seconds before it idles to neutral. Why it hang for 2 seconds and not straight away back to idle position?..Usually..once I release the throttle to neutral position..the engine will straight away back to neutral/idle position.
What should I do?..How do I troubleshoot this kind of problem?..Hope someone would help me out here...Thanks
AZMIN is offline
Old 01-27-2009, 08:28 PM
  #44
AZMIN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PINCH TEST
I did the pinch test and the engine stop in 3 seconds which means the setting is ok. However ..usually the engine will ramp up a little bit before it stops BUT this time it did not not ramp up at all. Whats wrong?..Any suggestion to rectify this OR it is normal for the engine not to ramp up before it stops? []
AZMIN is offline
Old 02-10-2009, 07:25 PM
  #45
Geoff78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am new to the R/C world and I have had the Tsunami for a few months now but I broke it within the first 10 minutes of owning it back in November. I finally decided to get the parts to fix it and want to operate it. My problem is though that I cannot get it to stay running once I take the Glow stick off of it. I followed all of the carb settings I found on here hoping that would work but it is not. Can anyone give me some insight as to what the problem may be?
Geoff78 is offline
Old 02-10-2009, 08:11 PM
  #46
perhamrocks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more than likely your settings are too rich, because the factory settings is just a general setting to get it running, but you will have to lean it out to get it to performing form. But if u are still breaking it in keep it as rich as possible while still keeping it running at the same time
Old 02-10-2009, 08:13 PM
  #47
Geoff78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What adjustments do I need to make to keep it running without the glow stick in place, while attempting to keep it "running rich"
Geoff78 is offline
Old 02-10-2009, 09:14 PM
  #48
perhamrocks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well first of all make sure the idle adjustment is good by taking off the air filter and making sure the opening in the carb is about 1mm. Then turn the highspeed needle all the way in, but do not tighten it, then take it 2 1/2 turns out. Then the low speed needle should be flush with the collar. if the car still loads up with fuel and dies after u take out the glow plug, lean out the low speed an 1/8 of a turn at a time. Also always make sure your exuast is spitting out plenty of blue smoke, and it should also be dripping unused fuel (for a rich setting).
Old 02-11-2009, 05:33 PM
  #49
rjsdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the rpm should raise a 1.5-2 seconds then shut off. If you are doing the pinch test and the rpm does not increase then you are running to lean. This is not good for the engine. Also look at your glow plug, if the coil are white then it is running hot (lean) The fuel is a lubricant as well for the engine.
rjsdad is offline
Old 02-11-2009, 09:39 PM
  #50
RedcatRacing
RedcatRacing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can go [link=http://shopping.netsuite.com/c.849850/site/videotraining.html]HERE[/link] to check out some new videos we have to help you get going and help with engine adjustments.
Darin
RedcatRacing is offline
Contact Us Archive Advertising Cookie Policy
