clutch bell, gear and spring install
VA
If everything goes right my tornado BB will be on my door step tomorrow. I already have my new clutch bell, gears, and clutch spring sitting here on my desk but nothing came with any instructions. Is there somewhere I can read some kind of instructions or does anybody have any advice for me before I go tearing my brand new car apart.
TN
RE: clutch bell, gear and spring install
What gear are you talking about? It aint hard at all take the 4screws loose on the engine and the screw and nut loose on the exhaust and you will be able to slide the motor out.Also take the top plate off too because it helps get the gear mesh perfect because you can see the gears better.Check the FAQ thread they have post on how to put the spring on and put the clutchbell on.
