Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
need alittle help
Reply
Old 01-18-2007, 08:08 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default need alittle help
OK my xp hasnt run right since I rebuild it awhiel ago.The probelm I have is when i tunr it on it runs wide open.It runs like I am pulling the trigger.It also will not shut off.Now i was told that it may have something to do with the throttle.I went and worked with it and I think i have it right now.My question is how can i make it stop running if it wont turn off without hurting anything?
Andyde4 is offline
Old 01-18-2007, 08:11 PM
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: need alittle help
pinch the gas line.
Chubbysdad is offline
Old 01-18-2007, 08:40 PM
dclintonh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
put your finger over the exhaust.
what did you rebuild?
the engine, or did you just take everything apart.
dclintonh is offline
Old 01-18-2007, 08:49 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[img][/img]i crashed it
Andyde4 is offline
Old 01-18-2007, 08:51 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats pic of it
Andyde4 is offline
Old 01-18-2007, 08:53 PM
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am happy I didn't put what I was going to put when you asked how do you shut it off. I was going to say, just run it in to a tree or a wall, everyone else seems to be doing that. lol Just kidding. Glad you got it back together.
Old 01-18-2007, 09:08 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that was a nice wreck, holy cow, what did you do?
ehroof is offline
Old 01-18-2007, 09:47 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hit a crub hard lol
Andyde4 is offline
Old 01-18-2007, 10:16 PM
dclintonh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was gonna say you might have bent somthing.
i guess i was right. sorry that just a thought.
anyway i had a problem that sound like your throttle prob awhile ago after i took mine completly apart.
unhook the throttle servo with the screw, push the throttle closed, start car.
them rehook everthing with the throttle in the same closed position.
good luck
Old 01-18-2007, 10:37 PM
mozzzy_2000
mozzzy_2000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds like the clutch shoes or springs to me. I'd check and/or replace.
mozzzy_2000 is offline
Old 01-18-2007, 11:53 PM
nitro_racer_1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it also could be a glitch in the radio, caused by low batteries or bad crystals. iv had that happen. the way to check is if the the throttle operates fine when the car is not running, and then stick at full when the car starts, its prolly a glitch
nitro_racer_1 is offline
Old 01-19-2007, 07:28 AM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that looks like a pretty nice hit, maybe you knocked the servo or servo horn or throttle linakge out of whack
ehroof is offline
MiniCwik
MiniCwik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also had this issue, as well as my bro-in-law ... make sure your clutch shoe spring is not bad or come loose on you. Can you roll it forward and backward easily with no resistance? Do you hear a metal on metal noise when you do? Can you start it easily while it is on the ground?
I'd also check the server/throttle operation with it not running but turned on. Does it go back to the 1-1.5mm opening in the carb when you let off of the gas or does it stick at WOT?
MiniCwik is offline
Old 01-19-2007, 10:31 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this is a picture of the set up.Can anyone see something i did wrong??
Andyde4 is offline
Old 01-19-2007, 10:34 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it looks good, do you thing or see something it did wrong?
ehroof is offline
Old 01-19-2007, 10:35 PM
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
By the looks of the pic, you need to pop off the star on top of your steering servo. It looks from here that your carb is wide open. Is it?
Old 01-19-2007, 10:38 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
actually the blue fueltubing by the servo horn is supposed to be between the brake adjustment and brake lever
ehroof is offline
Old 01-19-2007, 10:47 PM
Andyde4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i put new batteries in everything and did what you guys said and it still doesnt work right i was just woundering if anyone could see the probelm
Andyde4 is offline
Old 01-19-2007, 10:52 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
unhook the throttle servo horn, put the radio and car on, put the servo horn back on so the carb is only open a little for idle then try and see if the throttle opens and closed when you pull the triger.
ehroof is offline
Old 01-20-2007, 12:13 AM
abjones413
abjones413's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ehroof
In addition to that, make sure the THROTTLE TRIM is set to neutral and check your throttle switch to make sure it's not reversed. You'll be putting on the brakes when in actuality you will be going WOT...
Like ehroof said, it is very important that the transmitter and receiver are on. Push the carb throttle arm back all the way, ensuring the carb closes to the proper 1mm or 1/8" opening, then screw the horn back on the spline.
abjones413 is offline
Old 01-20-2007, 06:26 AM
123michael
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
do you know the servo horn slips i bought some new ones and new servos [8D]& horn and it is mutch better now the servos horn does not slip[8D]belive me it slips it took me a wile to figre out(mine does does yours)
123michael is offline
Old 01-20-2007, 07:43 AM
mozzzy_2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah check all your linkages as suggested above and if all else fails, look at the clutch. A dodgy spring or worn shoes will cause the engine to rev out uncontrollably.
Contact Us Archive Advertising Cookie Policy
