Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
need help with car
Old 01-26-2007, 05:31 PM
slide150
Default need help with car
my when i crank my car the wheels spin really fast and the car revs high i have all the settings back to factory settings so i could retune it. today i put on my tigerdrive and cranked it up and the wheels are doing what i said spinning could it be a bad clutch ? when i was running it before it wasnt doing that at all i even tried to play with the idle screw and it didnt work ne help would be apprieciated
thanx ahead
dan
Old 01-26-2007, 05:32 PM
slide150
Default RE: need help with car
oh i almost forgot when i roll the car forward i hear a clunk from the clutchbell
Old 01-26-2007, 06:08 PM
123michael
sounds like you need a new cluch springdont get redcat.
Old 01-26-2007, 06:11 PM
123michael
http://www2.towerhobbies.com/cgi-bin...?&I=LXUR89&P=7 get these cluch springs they hold well
Old 01-26-2007, 06:14 PM
slide150
i think i'm going to buy the teflon clutch shoes to replace the spring and the hpi clutch bell to replace everything in the whole shabang
Old 01-26-2007, 06:17 PM
123michael
what car have you got
Old 01-26-2007, 06:18 PM
slide150
its an exceed rc xtreme but all of the parts are compatiable with the redcat tornado
Old 01-26-2007, 11:21 PM
slide150
has anyone used the teflon clutch shoes hpi #A886: [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXVK12&P=7[/link] and will they fit with the hpi bell for the 2 speed
i just took my car apart the clutch is not round squared on the edges
Old 01-27-2007, 08:07 AM
ehroof
that clutch works but it gives a much higher stall rate so the clutch will not engage until higher rpm's but it does eliminate the spring. I switched back to the 4146x spring and stock shoes, just round the sharp edges with a file. the aluminum shoes work good with the hardened clutch bell.
Old 01-27-2007, 09:25 AM
slide150
ehroof if i do buy the teflon clutch should i set my gears to shift later because it enguages later
Old 01-27-2007, 10:01 AM
ehroof
no because the gears will still have to shift at the same rpm's, the clutch bell wont engage until higher rpms.
Old 01-27-2007, 01:22 PM
slide150
thanx man one more question if i dont use it u use the traxxas spring with the stock clutch shoes
Old 01-27-2007, 01:54 PM
ehroof
yes, 4146x spring with the stock redcat clutch shoes.
