Redcat Racing Volcano Thread
#526
RE: Redcat Racing Volcano Thread
ORIGINAL: nitrozach54
i have the sv
can some 1 please show me with pictures and directions of how to set up my my throttle and brake servo?
im having trouble of where to set the arms and all
please help so i can run my truck
i have the sv
basically you put the transmitter and car on, put the trim knobs on the transmitter to the center, try to put the throttle arm on the throttle servo so the carb is 1mm open and the brake is not on or as close as possible, put the arm on the steering servo so the wheels are as close to straight as possible then trim them the rest of the way with the trim knobs. is this what you wanted to know? there is no real set way, if you need, check out the pictures on the redcatracing.com website at the volcano to get a basic idea of how they go.
#530
i have a volcano sv. the linkage that goes into the gear box broke. i can pull the rod completely out. the engine starts and when you squeeze the throttle it revs but the wheels dont turn. i need some suggestions on what to do.
#531
Banned
VT
what do yall think of the electric starter?
my pull is broken and electric is $7 more
http://cgi.ebay.com/Power-Starter-fo...QQcmdZViewItem
#532
ORIGINAL: jaybird84
do you mean the brake linkage? if so, there is a small grub screw that hold it in place, right on top inside the chrome piece above it. check the grub screws in the drive cups (cups that hold the dogbones). also make sure the slipper clutch is tight on the trans, its the nut behind the spur gear.
#533
seems like a good deal, i dont like rotostarts, you need that charged battery all the time, not saying its not good, i used to love it on my hpi till i showed up to the track with a dead battery, within a 1/2 hour i had a pull start on it and a starter box.
#534
its the chrome piece that goes into were all the gears are that is also attach to the throttle the chrome rod now can be pulled aot easly so do i need to take all that apart and if so is there an easyer way then taking the whole car apart?
#535
thats the brake rod, there is a pad behind the brake that the flat part of that rod sits one. should stay in place if installed right.
#536
Banned
VT
i had my first run in the snow and first fun in 6 monthes!
any suggestions of after run in the snow
i just take the upper plate off and take all the snow off that i can and put it next to the furnace
any ofther tips to prevent anything bad?
#537
Banned
VT
god ehroof i was just looking through your gallery
what do you do for work to have that many R/Cs????!!!!
I was like.... [sm=omg_smile.gif][sm=greedy.gif][sm=greedy.gif]
#538
spray the whole rc down with wd40 before you run it and after when its dry, blow off the excess if you have a compressor or can of air.
#539
lol and thats not all of them. I am a GC in NYC and the 5 boro's but i am looking for something else to do soon, dont know what yet. lol
#540
ORIGINAL: ehroof
Banned
VT
I just wanted to know if any 1 had any experence with the same system
whats a GC?
and how did you stumble upon my video?
http://www.youtube.com/watch?v=Khmm2aOQRc8
whats a GC?
#545
Banned
VT
http://www.redcatracing.com/itemdeta...p?partno=08018
http://www.redcatracing.com/itemdeta...p?partno=08022
will these replace my front and rear drive shaft and drive cups?
Parts below
http://www.redcatracing.com/itemdeta...p?partno=02016
http://www.redcatracing.com/itemdeta...p?partno=08061
http://www.redcatracing.com/itemdeta...p?partno=08060
because one fell off today and i couldnt find it!
Parts below
#546
whats a GC?
whats a GC?
GC=General Contractor
#547
it does stay in place but i tore the gasket and dont know where to get one any ideas?
#549
Banned
VT
Parts below
Parts below
#550
PLEASE help?
Parts below
Parts below
the 2 shafts on the top are for the transmission, the gears go on them
02016 are for the front and rear diff,
02003 goes from the trans to the rear diff
06006 goes from the trans to the front diff
