Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Volcano Thread
Reply
Old 05-06-2008, 08:37 PM
  #1151
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Volcano Thread
u mean the part of the clutch bell with no teeth??
I will give it a look but problem seem to be fixed after I alligned the brakes if its hitting how do I bring it back?? I will look and post backk
Gelo_USA is offline
Old 05-06-2008, 08:41 PM
  #1152
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nope.. I have good clearence there... only concern is the metal gear by the spur gear is really worn... but the plastic gear IS FINE the one tht makes contact with the worn metal gear... FUNNY HUH... plastic wearing a metal gear out.. thts only after 3/4 of a gallon throught the truck...I expected this to start happening on the 3rd gallon or so....
Gelo_USA is offline
Old 05-07-2008, 06:25 PM
  #1153
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
okk ran it outside.. worked for a while and started locking by it self again...... the clicking is exactly on the brakes so I think my disk is messed up or something...I will take it out tomorrow see if its alright...as for the locking part I dnt knw what the hell is happening but now I can see the "shoes" closing in on the disk whenever I roll the truck... I got mad and held the brake with my hand all the way and revved the engine to waste a little of the shoe or something... problem went away... I still got the clicking tough... I m going crazy already...
yesterday when taking the truck apart I saw the blue rubber from the pipe was leaking thts why I was getting so much grease all over the rear right shocks so I took it off and reasembled it with new wraps I expected I would have to tune the engine again but man I couldnt find the right spot after the leak is gone... its still a little too rich but I have no time to play with it today... the noise is also more annoying now...
Gelo_USA is offline
Old 05-08-2008, 05:47 AM
  #1154
kutzie1793
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heyy i have a volcano sv. i broke a front axle, so i pulled out the other one so its just rear wheel drive. is this bad for it?? what should i take out to make it run better as rear wheel drive? and also, my trucks pretty stock. where can i get an engine just big enough to pull a wheelie (used, very cheap[like under 30bucks])??
kutzie1793 is offline
Old 05-08-2008, 03:50 PM
  #1155
kutzie1793
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heyy its me again. i completely stripped the gear thats driven directly from the clutchbell. is this common? can i get one cheaper than on redcat's website? and can i get a metal one?
Old 05-08-2008, 04:51 PM
  #1156
ranger4x4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that gear is called a spur gear, and no metal spur gears are a bad idea for them. they are plastic so that part fails if there is a problem and to save the rest of the driveline. you could look at allaboutfunhobbies or send an email or pm himotoracingusa. he might be able to help you out as well.
ranger4x4 is offline
Old 05-08-2008, 08:26 PM
  #1157
RACINFORFUN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I OWN A VOLCANO SV HOW DO YOU TAKE THE STEERING HUB OFF?
RACINFORFUN is offline
Old 05-09-2008, 03:12 PM
  #1158
RCToysNh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You want part number 08013
We have them on our site.
RCToysNh is offline
Old 05-09-2008, 04:08 PM
  #1159
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is the rear differential the same as the front?? what are all the parts tht build a full differential?? I want to keep a whole one extra cause my front one seems to be the CLICLKING problem I am having... so I think its about to go soon.... I want to have an extra for when it breaks....
EdIT** also... what kind of oil/grease do I use inside the differential when rebuilding it...
Gelo_USA is offline
Old 05-09-2008, 11:08 PM
  #1160
numskull223
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes the same. It catually looks just like a real life rearend. It has a ring gear and a pionion gear. Check to see if the c clip as came off the Pionion gear, could cause clicking souund.
I have noticed that when I apply the brakes, you can hear a lil clicking sound, but I knoe its the brakes, but I havent had the brakes lock up by there self. Good Luk.
numskull223 is offline
Old 05-10-2008, 08:26 AM
  #1161
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also when I rev it full thortle from stopped I hear the click too... I will open up the differential todayy.. see if I find anything wrong....
Gelo_USA is offline
Old 05-10-2008, 10:38 AM
  #1162
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
diff is all ok... all metal gears.. I thought they were plastic... my problem is on the trans then for sure.. I got an spur gear kit.. I will try replacing the smaller metal gear cause the big one is fine the small is a little worn.. not too much but might be it.....
Gelo_USA is offline
Old 05-10-2008, 06:24 PM
  #1163
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man its frustrating... I've taken the whole truck apart everysingle screw.... I cant find anything wrong.... today I finally found the sweet spot on tunning truck is running like hell... almost doing wheelies on grass but now its clicking way more when I rev it and when I brake... I tried braking and reving it to 100% for a while just full speed stop full speed stop but the damn part thts cliclking WONT BREAK ... I just want it to break now so I can see it and replace it... all differential gears are fine... clutch bell has no wear spur gear has no wear... I am starting to notice tht when it clicks I loose performance.... and when braking and it clicks its like the car runs loose for a sec of the click and locks again...I am already annoying everyone here I knw but this is suppost to be the official redcat racing support and I cant get any answer from them.......
I knw I am not doing anythign wrong... and there is no broken or stripped gears... now I m starting to regret saving 100$ cause I would've been better of paying more and not having this S#!T problem and no support
srry guys its nothing against u guys in the forum... I m pissed at redcat cause I email them and NOTHING.. I post here and NOTHING... its just frustrating....
Gelo_USA is offline
Old 05-10-2008, 07:11 PM
  #1164
Boxhead from MN
Boxhead from MN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you checked that the set screws on the drive cups are set on the flat spot? Just a suggestion.
maybe the linkage for the brake is binding? Had mine out yesterday and didn't hear a clicking sound.
Hope you find the problem.
Chris
Boxhead from MN is offline
Old 05-10-2008, 07:17 PM
  #1165
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what are set screws exactly... I took it all aprt but dnt knw what those are.... what cups are u talking about?? the ones on the wheels.. transmission or diferentials???
Gelo_USA is offline
Old 05-10-2008, 11:01 PM
  #1166
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the drive cups are what the dog bones go into, there is a grub screw that tightens on a flat spot ot hold it
chevyderek72 is offline
Old 05-10-2008, 11:13 PM
  #1167
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the screw is inside the cup?
Gelo_USA is offline
Old 05-10-2008, 11:32 PM
  #1168
numskull223
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check ur servos, I had one clicking on mine tonight, when I was adjusting the throttle, It was constantly clicking as long as I held the throttle down.
also, set the truck off the ground and crank it, run it, that way you can investigate the sound, while its running.
Old 05-10-2008, 11:36 PM
  #1169
numskull223
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kutzie1793
2.5r traxxas engine or 3.3
Old 05-10-2008, 11:38 PM
  #1170
ugly duck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it under light braking or heavy braking? Have you checked the rotor for warp? Have you checked the brake "caliper" squareness to the driveline? (If the two bolts holding the brake pads are tightened down differently so that the pads are trying to twist the rotor on the transmission output shaft, you'll get a clicking)
There are things to check out, but ultimately you've got to be the one to find it.
ugly duck is offline
Old 05-11-2008, 12:01 AM
  #1171
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I`d do like numskull said. If your lacking performance maybe the throttle servo is slipping and would cause breaking problems too. You can take it out of the truck and take the top off the servo and look for stripped gears. I hope you find the problem but thats where I`d start.
Swamp3r is offline
Old 05-11-2008, 01:01 AM
  #1172
Greenf41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey all found this thread about redcats, lot more posts than I thought.. wanted to post pics of my volcano and show it off, my friend and I have done two big block conversions now, and the truck works pretty well now with the metal spur gear. the next thing we need is a stronger diff, let me know if you have a way to upgrade the ring and pinion.. it pulls very nice wheelies, want to get a video up on youtube and try to get a top speed on this thing, whats the easiest way to do a top speed test? we were thinking of driving next to a real vehicle.. just seems to risky, is there a cheap radar gun?
http://www.rcuniverse.com/gallery/ga...memid%3D415327
sorry if the links dont work im not familiar with the forum yet
Greenf41 is offline
Old 05-11-2008, 01:14 AM
  #1173
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nahh.. problem is not with the servo.... the calipers of the brake are square..... the problem happens when I brake fully or only slightly... when I rev it.. it clicks too..
i tried running it on my hand to hear the clicks where they are comming from but it only happens under load.. when the whells are off the ground it runs smoothly
Gelo_USA is offline
Old 05-11-2008, 01:42 AM
  #1174
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I`d still check inside the servo if under load it does it it could be a stripped gear. Not under load means the servo doesn`t have to work as hard hence no clicking. I`m just trying to help you, if you have ripped the truck apart then why not go the extra step and look at the servo.
Swamp3r is offline
Old 05-11-2008, 08:48 AM
  #1175
ugly duck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Greenf41
Nice truck! What transmission are you running and what is this metal spur gear you speak of?
Contact Us Archive Advertising Cookie Policy
