Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Volcano Thread
Reply
Old 05-11-2008, 11:21 AM
  #1176
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Volcano Thread
thanks for the patience everyone...
BROKEN TOOTH on a gear inside the rear gear box... damaged the ring differential gear... so now I need a ring gear and the gear tht drives the ring gear..... can anyone ship it to me FAST??
Gelo_USA is offline
Old 05-11-2008, 01:23 PM
  #1177
Greenf41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ugly duck Thanks! the tranny is a redcat 2 speed that with some tweaking we put an hpi 47 tooth savage gear on.. the plastic redcat gears would actually MELT when we would idle for a bit with the .32 so the most we ever got out of a plastic gear was 5 or 6 tanks and that was really annoying changing that gear all the time. now im on my third ring and pinion.. So welcome to the club Gelo lol..
anyway, as far as the metal gear goes.. I dont know how well it would work with a small block, since the redcat 2 speed wouldnt work on the volcano.. it had no power. I think 47 tooth is the 2nd gear, but with 3 horsepower it still has plenty of torque. to keep the small block and have a better tranny I dont know how to help... 47 tooth is just about the bigest one I can fit on my truck so unless you add more power I dont know how to get away from that gear reduction.
Greenf41 is offline
Old 05-11-2008, 01:30 PM
  #1178
Boxhead from MN
Boxhead from MN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gelo USA,
Got your PM. Sent you one.
Boxhead from MN is offline
Old 05-11-2008, 05:02 PM
  #1179
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does part number 08023 come with the brakes and cups too??
Gelo_USA is offline
Old 05-14-2008, 12:01 PM
  #1180
RCToysNh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No.
to Complete unit you would need
08023
02044 Brakes
02016 Cup
02034 Cup
RCToysNh is offline
Old 05-14-2008, 04:52 PM
  #1181
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ohh ok thanks... cause I might need a new set... hope not.... waiting for some other gears see if it fixes my problem... if not I will try replacing the whole transmission assembly.... its the last shot...
Gelo_USA is offline
Old 05-14-2008, 05:05 PM
  #1182
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just out of curiosity cause I knw one day I will have to do it...
how do I rebuild an engine?? and how many gallons before I need to do it??
wich one is better... the sh .18 or the team infinity .18 I cant find parts for team infinity... Can I use a regular .18 carb with 3 nedles on my team infinity wich the stock carb has only 2 and its kind of hard to tune it.???
Gelo_USA is offline
Old 05-14-2008, 05:25 PM
  #1183
Redcat Nick
Redcat Nick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most time all you need to do is replace the piston and sleeve. there is a thread some where here on that.
Now for the infinity .18 and the sh.18. I would go with the sh.18. FOr one i like it way better and for 2 you can't get parts for the infinity .18 because infinity went out of business.
As far as gallons through your engine. all depends on how it is tuned and how hard it is run. could be 1 gallon to 10 gallons.
the sh.18 is very easy to tune. another plus
Redcat Nick is offline
Old 05-14-2008, 07:39 PM
  #1184
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea I realized it was hard to find parts for the infinity.. I was gonna get a piston an a sleeve to keep at home but cant find it ... oooo well.. when I need to rebuild it I will just send it to redcat and get an SH... I can understand its easyer to tune... it has the 3 needdles the infinity has only 2.. no low speed needle
Gelo_USA is offline
Old 05-16-2008, 06:49 PM
  #1185
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mann.. the fuel tube is too close to the trans... it turns so tight it seems like its reducing fuel flow.. has anyone done anything to fix it??? I was thinking of getting longer fuel lines and flip the tank with the output to the front....tht way I have more time when I flip the truck to run and flip it back.... and the line wont be so close to the gears....
EDIT*** cant flip it...
I tried to pull the pull start... its loose... like the cord comes in and out normally but it doesnt spin the motor... it spins like only one cycle and gets loose...do I need a new pullstart?
Gelo_USA is offline
Old 05-17-2008, 04:57 PM
  #1186
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no your one way bearing is slipping. mine is doing it but i just keep pullin then when it starts it doesnt slip anymore till its cold again. or just take it out and clean it
chevyderek72 is offline
Old 05-18-2008, 06:34 PM
  #1187
perhamrocks
perhamrocks's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ya that happened to me too, but i just left it and pull on it till it starts. Which takes a while some times when it's slippin
perhamrocks is offline
Old 05-19-2008, 01:21 PM
  #1188
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok it broke... I need a new one... the spring broke... wich one should I buy I only see the one for the SH.. can I get it in a local hobby shop is it a standard size for .18 engines??
Gelo_USA is offline
Old 05-19-2008, 06:14 PM
  #1189
RCToysNh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take the starter off, remove bearing and clean it with wd40 or other.
Then oil with light oil - sewing machine or air tool oil works well.
DO NOT BLOW THE BEARING DRY WITH COMPRESSED AIR
RCToysNh is offline
Old 05-20-2008, 04:43 PM
  #1190
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took it apart.. the return spring broke... the hardest things to happen.. HAPPEN TO ME ALL THE TIME... lol I still havent figured out the clicking noise... I replaced both diffs... now I m waiting on the pullstart and a full new trans assembly EVERYTHING cups brakes and all... [&o]
if I could make it work right I might even buy a buggy soon... but I cant even figure out this one.... I jst dnt knw if the buggy is gonna be redcat...I m scared I will save some bucks but have the same problems... redcat nick is being very very very helpful.. but we cant figure it out and the truck came with tht problem already...
for the pullstart I have no idea how it broke cause I ve heard they last a long time and I only had a gallon through the truck... and always pull it like only half way... enough to get it running...
Gelo_USA is offline
Old 05-21-2008, 04:30 PM
  #1191
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man... I finally found my clicking problem.... the diff between the pinion and ring gear on both diffs... it has a play of more then a 1/16 of an inch and I tested the diffs separately and they are the "clickers" lol but thts how they came from factory... maybe it came missing a washer or so but can any of u guys tell me where should I have a washer inside the diff if there is any and the sizes... cause mine has none.. it has a little play thts why I am assuming there should have been washers...
Gelo_USA is offline
Old 05-24-2008, 02:12 PM
  #1192
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my body is messed up and I dnt want to order it online...
does any 1/10 body fit?
Gelo_USA is offline
Old 05-24-2008, 05:44 PM
  #1193
RCToysNh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We have clear unpainted and pre painted for the Volcano
RCToysNh is offline
Old 05-30-2008, 04:18 PM
  #1194
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys.. finally got my volcano pro fixed... with redcat nick's help....after a gallon through the truck I will have my first run with the truck running correctly only this weekend but thinking on the brighter side at least now I knw how everything on the truck works... everysingle part.....andddd I have bought almost all the parts for it trying to find what was wrong so I have tons of spare parts now...
I was looking forward into an hurricane pro but cant find it anywhere I want to buy one some time in the next few months....
my steering servo went crazy.... I m using a futaba one I had with a horn I made but it dsnt have that much strength... what servo do u guys recommend tht will fit the stock servo horn.... something I can get in a lhs cause I dnt want to wait for shipping.....
Gelo_USA is offline
Old 05-30-2008, 09:00 PM
  #1195
JAMBF750
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Redcat Nick
...Now for the infinity .18 and the sh.18. I would go with the sh.18. FOr one i like it way better and for 2 you can't get parts for the infinity .18 because infinity went out of business.
I wish I would have known this prior to my purchase…
JAMBF750 is offline
Old 05-31-2008, 12:34 PM
  #1196
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how do I knw if my clutch needs to be replaced?? how often do they usually go bad if the idle is properly tuned??
Gelo_USA is offline
Old 05-31-2008, 01:38 PM
  #1197
racemaxx24
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will be slugish and act like the engine has no power. If u keep trying to tune it and it still doesn't seem like it has any power, always put checking your clutch and the check list. Also, if the clutch spring breaks, it will lock against the CB and it won't start + when u pick it up and pull the P/S, the wheels will move. A clutch on that truck should last 4-5 gallons depending on how u drive
racemaxx24 is offline
Old 05-31-2008, 05:59 PM
  #1198
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ohh... just curiosity....
I did noticed the performance decreased but I m sure its not the clutch... its probably the glow plug... I ran a gallon already and replaced the glow plug only once....
I think I will be buying a tornado s30 instead of a 1/8.. parts for the 1/8 are more expensive...I only wanted for fun... running around the street and bashing so the tornado s30 will do it...
Gelo_USA is offline
Old 05-31-2008, 07:28 PM
  #1199
jellypotato
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought this redcat volcano three days ago... had a total of less than 12 tanks of 20% fuel thru it... Problems : First 8 tanks are for the break-in process, and right after the 8th tank, glow plug burns out, which is normal.... Then replace it with an OS glow plug no.8, start the ninth tank, it runs for half a tank, one way bearing gives... breaking my pull start with it and striipping it, stalling the engine and killed my glow plug. I took out the pullstart, gut out the contents and put the cover back on, change the glow plug, and use a starter box to start it instead of replacing the bearing and pullstart.... Then after around 2 tanks, engine stalls and I couldnt get it to start again, the flywheel is stuck !! Took it home and take the engine apart, found that the piston and connecting rod broke !!! Couldnt believe redcat stuffs is this fragile !!! and I was only running on the parking lot, no dirt, no grass....
I know I'm running the engine the correct way, not too lean...
My advise : Stay away from them.... spend a little more money and get decent brand for prevent future headache !!
And about redcat engine replacement warranty, it's a hassle.... and who will know how long it takes for them to send it out if ever they approve it. I hate to leave my rc car sitting there collecting dust, but what else can I do ?? Guess its time to junk it and get some well known brand names....
jellypotato is offline
Old 05-31-2008, 07:30 PM
  #1200
jellypotato
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Reply
Display Modes
