Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Volcano Thread
Reply
Old 05-31-2008, 07:37 PM
  #1201
Boxhead from MN
Boxhead from MN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Volcano Thread
Need help. Lost the screws that hold the pullstart on. Anyone know the size?
And Jellypotato, I've heard of other brand engines failing so it's not just Redcat.
I've ran over a gallon through my Redcat and the only problems I've had are the
pullstart coming loose (my fault no lock-tite) and the steering (too loose).
Chris
Boxhead from MN is offline
Old 05-31-2008, 09:14 PM
  #1202
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well you were using the wrong glow plug, your supposed to use the number 3.
chevyderek72 is offline
Old 05-31-2008, 09:27 PM
  #1203
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could a wrong glow plug cause this kind of damage??
or could it be because of the one way bearing failing??
Gelo_USA is offline
Old 05-31-2008, 11:05 PM
  #1204
ugly duck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Judging by the condition of the wristpin, it looks like you were too lean. What kind of fuel were you using?
ugly duck is offline
Old 05-31-2008, 11:54 PM
  #1205
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yep.....
My Money is on "too Lean".
Also.....maybe the flywheel nut came loose and the crank was able to move with More play than it normally has.....
Did you bugger up the Spur gear? That would be sign of a wandering crank....
Redharris is offline
Old 06-01-2008, 02:27 AM
  #1206
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jellypotato
Now I'm craving a mc chicken and fries, you could have used a different napkin in the pic lol. From what I've read the engine replacement isn't a big deal to put up with. I'd use the replacement program and get a new engine, also were you setting your engine to bdc and using after run oil. It's just a thought, but using the wrong glow plug could of caused it for sure if it was too long into the cylinder. I don't know the plugs that your using so I don't know if the depth is different. I hope you don't give up on the truck man they are good rc's.
Swamp3r is offline
Old 06-01-2008, 02:49 AM
  #1207
jellypotato
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wrong glow plug ???? Even if it's the wrong glow plug, it wont cause the crank to break like that... and I know I'm not running it too lean. I read in some japanese manual for the os glow plug and says that no.3 is for fuel less than 20% and used on airplane engines or .12 car engines... and no.8 is for .18 engine using 20% fuel... So leaning out the engine and wrong glow plug rules out.... My guess is the quality of the material... anyone with me ???
jellypotato is offline
Old 06-01-2008, 02:51 AM
  #1208
jellypotato
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nah..... when I checked the engine, none of the parts or screws were loose.... and the fly wheel were just like brand new
Old 06-01-2008, 03:04 AM
  #1209
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I doubt the quality of the material I have 3 redcats all sh engines and I have bought 4 gallons of fuel in the past 2 months I still have 3/4 of a gallon but all 3 of my trucks run awesome. So you know I've ran the hell out of these trucks it isn't a quality problem so you can rule that out.
Swamp3r is offline
Old 06-01-2008, 03:05 AM
  #1210
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can you show me a pic of the top of the piston?
Swamp3r is offline
Old 06-01-2008, 05:42 AM
  #1211
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a guess, but to me you might have put it on the bump box wrong. The one way might have caught(only supposed to catch in one direction). You can put a car on bump box wrong.
Chubbysdad is offline
Old 06-01-2008, 04:32 PM
  #1212
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran my truck today... but it keeps dying when I release throtle after a few minutes of running... the idle is set right...the motor is not overheating I tried putting some water drops on the head and it takes some secs before it dessapears... it doesnt even sizzles.... and the throthle servo is adjusted....
when it dies like tht its kind of hard to make it come back.....I have no idea what it might be.... I m running a little on the richer side... affraid to damage the engine....
also the clutch bell is starting to get like brownish golden.. like when u heat metal... but I think thts normal right?? I ve seen lots of pics with the clutch bell like tht....
I m buying anyways... a full clutch assembly with clutch bell and bearings jst to keep it as a spare....
Gelo_USA is offline
Old 06-01-2008, 06:25 PM
  #1213
racemaxx24
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lean her out. That will help alot. The clutch bell will turn brown a bit but not much
racemaxx24 is offline
Old 06-01-2008, 09:49 PM
  #1214
luxuryblue883
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just got my first Nitro a Volcano SV. After the 3rd tank of fuel I have no brakes and only the front wheels drive. I am assuming I need to pull the rear differential out and replace gears. Little dissapointed that I have to start replacing things already. Or could it be something simple?
Thanks. DId some searches but not always sure what people are talking about.
luxuryblue883 is offline
Old 06-01-2008, 10:18 PM
  #1215
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No rear Drive?
Check the Rear Drive Cup on the Transmission. It is Notorious for comming loose.
In Fact, (with a new Vehicle) Check ALL of your screws and fasteners for Tightness and LocTite any screws that attach to Metal.
Old 06-02-2008, 07:17 AM
  #1216
luxuryblue883
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No rear Drive?
[/quote]
Thanks, Will check it tonight and see what happens.
Old 06-02-2008, 08:20 AM
  #1217
ugly duck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure you get the grub screw properly lined up with the flat on the transmission shaft when you tighten it, otherwise you'll lose rear drive again in about 1.5 seconds. And use Loctite - people say blue, I'm gonna say red on this part. In order to release red loctite you need some heat, but you shouldn't need to release it any time soon.
Old 06-02-2008, 04:33 PM
  #1218
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mine came with lock tite already but I would give a check anyways because my truck came with lock tite but came missing washers on the diffs LOL... HUMANS!!! hahahaha maybe they forgot to lock tite it.. also check the cup on the rear DIFF as it could also be ur problem..... or maybe not cause if it was the cup on the rear diff u would be able to break.....
Gelo_USA is offline
Old 06-02-2008, 06:01 PM
  #1219
ugly duck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Gelo_USA
exactly.
Old 06-02-2008, 07:51 PM
  #1220
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got my volcano running perfect today.. doesnt die anymore but I think its too hot is it normal??? I didnt think it was suppost to get this hot thts why I was running rich a little.... now I still get a lot of blue smoke out but it doesnt die... and the head is hot enough to fry my finger if I touch it for a couple of secs... if I put couple of drops of water it sizzles and evaporates within 5 secs... is it too hot??? I think I got the perfct tune cause its running perfect and is not dieing...
another question.... most of the parts from the volcano are compatible with the tornado right??? like the front and rear gear box...??? I might give up on the hurricane and get a tornado because of tht.........
Gelo_USA is offline
Old 06-02-2008, 07:58 PM
  #1221
luxuryblue883
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the help. Had to pull the tranny out to re attach the cup set screw (with loctite) because the brake was in the way. But now I know how to pull it apart and I have 4wd drive as well as brakes again. and the amazing part is that there were no spare screws left on the bench when I was done. Thanks Again !!!!
Old 06-02-2008, 08:00 PM
  #1222
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol on the no spare parts
Swamp3r is offline
Old 06-02-2008, 08:02 PM
  #1223
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol.... its good when "bad" stuff like tht happens.... I have my volcano for a month.. in 2 weeks I knw it inside out... everything... because whoever BUILT it at the factory made the favor of not putting the spacers in the front and rear gear box so I took it apart like 100 times went through 3 sets of diff gears before I found out but now I knw everyscrew on it..... LOL .. and thts a part of the hobby.... taking it apart and fixing it... thts one of the reasons I like RCs in general....
Gelo_USA is offline
Old 06-02-2008, 08:03 PM
  #1224
Gelo_USA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BUMPING.... (if this is not allowed in this forum let me knw and I wont do it again)
"got my volcano running perfect today.. doesnt die anymore but I think its too hot is it normal??? I didnt think it was suppost to get this hot thts why I was running rich a little.... now I still get a lot of blue smoke out but it doesnt die... and the head is hot enough to fry my finger if I touch it for a couple of secs... if I put couple of drops of water it sizzles and evaporates within 5 secs... is it too hot??? I think I got the perfct tune cause its running perfect and is not dieing...
another question.... most of the parts from the volcano are compatible with the tornado right??? like the front and rear gear box...??? I might give up on the hurricane and get a tornado because of tht........."
Gelo_USA is offline
Old 06-02-2008, 09:22 PM
  #1225
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you should be ok on your tune. it should evaporate or whatever in like 5 seconds, but i know for sure im running too rich when im running wot and it cuts out. then i richen it up a bit.
Contact Us Archive Advertising Cookie Policy
