Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Volcano Thread
Reply
Old 03-25-2009, 06:03 PM
  #1476
richardtf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Volcano Thread
got it firebird!! my truck is running now!! whats the best upgrade to increase speed/power of volcano sv? :-) thanks
richardtf is offline
Old 03-25-2009, 09:55 PM
  #1477
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A new motor would be the best, but a pipe and header always help tons.
chevyderek72 is offline
Old 03-26-2009, 12:31 PM
  #1478
richardtf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what motor would fit? :-)
Old 03-26-2009, 05:05 PM
  #1479
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The sh 18 is a great upgrade, and you can get it half off through the redcat engine replacement program. and the os is better, but its more expensive
Old 03-26-2009, 05:33 PM
  #1480
perhamrocks
perhamrocks's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i'm not sure if the engine mount holes are the same, but the new sh .21 for the landslide has a side exaust. it would probably give ur drivetrain some issues tho, and it's also a slide carb, but that's not a huge issue to overcome
perhamrocks is offline
Old 04-03-2009, 07:05 PM
  #1481
wlind05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone noticed the spur gear not being true?
wlind05 is offline
Old 04-03-2009, 07:15 PM
  #1482
wlind05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I Have found a solution to fix the rear diff on the volcano sv. THe solution although appearing to be obvious the results in performance are amazing. Heres what you do take out the diff and dissassemble it including the carrier, so you can get to the spider gears. Clean everything real good with brake cleaner, the reason you use brake cleaner is it removes the grease and does not leave a film. With everything in place inside the carrier fill it with 2 ton epoxy or something similar and reassemble. Once cured it will be a locked rear end. Reinstall the diff and enjoy![8D]
wlind05 is offline
Old 04-04-2009, 12:35 AM
  #1483
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya but then its locked, it makes the car harder to turn. You will get better traction but your handling will suffer
Old 04-04-2009, 11:50 AM
  #1484
wlind05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes that is true.... If you run it on blacktop or if all you do is run at full throtle all the time, but for off road like dirt and sand it does't really hurt the handeling. Good point and i should have mentioned that.
wlind05 is offline
Old 04-14-2009, 10:35 AM
  #1485
arcticw01f
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the factory carb settings for the volcano?
arcticw01f is offline
Old 05-13-2009, 06:28 PM
  #1486
big hec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys i just do not know why my volcano sv s30 use a lot of nitro i do like four passes and then i have to put more nirto in the truck i do not know why it dose that if any body can help me out that be great but i love this truck
big hec is offline
Old 05-13-2009, 09:32 PM
  #1487
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You probably have a crack in your tank. Take your fuel lines off the exhaust and motor, and pinch one and blow in the other. I gauentee thats what it is. There is no reason other than that to why it goes that fast.
Old 05-14-2009, 07:22 AM
  #1488
big hec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks chevyderek72 i will try that and see if thats it i knew something was wrong but did not know what it was i thought it was tune wrong our something i'll let you know if that was the problem thanks
big hec is offline
Old 05-30-2009, 09:25 AM
  #1489
big hec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does any body know if there is a bigger  fuel tank  that i can put on my volcano sv s30 if so can anybody  give me a web site where i can buy one
big hec is offline
Old 05-30-2009, 09:57 AM
  #1490
big hec
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey chevyderek72 thanks i did what you told me to do and i found the problem it was the fuel filter that i put on it was lose so the gas comeing out of it the way i fond out was i did what you told me to do but i took off the filter and every thing was good so i was still wondering whats wrong so i put nitro in it and ran it and it was still useing a lot of nitro and the truck was covered with fuel and oil so i took a good look at the filter and it was all fill of fuel and oil and dirt so i took it off and check it and all this time it was lose so if anybody buy one of these thing make sure it's good and tight
big hec is offline
Old 05-30-2009, 06:36 PM
  #1491
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haha no problem, so your fuel filter was just loose and leakin tons of fuel?
Old 06-01-2009, 10:05 PM
  #1492
bentuhley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the screws going from my engine to my exhaust manifold vibrate out. I was looking to order them but wasn't quite sure on the part number. I found some with part #02094www.redcatracing.com/RC-Cars/02094, But wasn't quite sure it is it. Also should add lock tite to these screws never really thought to since it was going through the engine wasn't sure that I should.
bentuhley is offline
Old 06-01-2009, 10:17 PM
  #1493
rclynx
rclynx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lock tite is always a good thing to use but the best thing that I know of is buy a screw a little longer than the ones it comes with and install a nut on the other side.........That doesn't come loose to often good luck and HAPPYRC'en
rclynx is offline
Old 07-21-2009, 09:38 PM
  #1494
aldwardo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been having a problem with stripping and breaking the screws going through the chassis in to the engine mount. I would like to replace them with stainless hex if I can find them. Does anyone know what size they are off hand, or where I could find something like that?
Also, having some steering problems. The servo is pushing but something isn't letting it turn far. Seems to be happening since I installed aluminum arms. I tried loosening the ball screws in the joint, but that doesn't seem to help. Any ideas of what to try would be appreciated. Thanks!
aldwardo is offline
Old 07-21-2009, 10:19 PM
  #1495
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to your local hardware store and find something that fits. And as for the steering, its your servo saver, this thing- http://www.redcatracing.com/RC-Cars/02025 Whats happening is that its loose so when you turn it opens up, its supposed to do that incase you hit something and your wheels have to turn, so it doesnt ruin the servo. Tighten it using that metal piece and you'll be good.
Old 07-21-2009, 11:52 PM
  #1496
bkfamily1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those screws are 3mm. It's damn rare to find 3mm in a hardware store. Even if they have metric, very few go that small. And finding metric in stainless with a hex head at the hardware store??? No way unless you have the king of all hardware stores. Try your local hobby shop. You can also try [link=http://www.mcmaster.com/#]McMaster-Carr[/link]. I think they have the widest selection of that kind of hardware, the prices are really good as long as you do not mind getting 25 or 50 or 100 instead of 2 or 4, and their search function is really good for finding what you want.
I would guess you want something like [link=http://www.mcmaster.com/#92855a313/=2ummcr]this[/link] or [link=http://www.mcmaster.com/#92095a183/=2umn9q]this[/link] or [link=http://www.mcmaster.com/#92137a254/=2umnru]this[/link] although I am not sure about length. And if you are getting stainless because you want a stronger material,that may not be a good choice. In low profile socket head cap screws (the first link), for example, the class 8.8 steel actually has higher tensile strength than the 18-8 stainless version of the same screw. Check the material info on [link=http://www.mcmaster.com/#catalog/115/3084/=2umpgb]this[/link] and other catalog pages.
bkfamily1 is offline
Old 07-22-2009, 01:37 AM
  #1497
chevyderek72
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found some at ace hardware that were like in the second link.
Old 07-22-2009, 06:26 AM
  #1498
bkfamily1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then you are truly blessed with an excellent hardware store. I wish I had a store that good near me. Most do not go down to 3mm, and if they do, it is very uncommon to find them in specialty types like stainless steel and hex head. Nonetheless, it is worth a phone call or stop to see if they have them near you. In my area, you are best to use the LHS if you want to pay more for fewer but want them right away. Otherwise, McMaster offers the best option.
Old 07-22-2009, 08:46 AM
  #1499
aldwardo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much! I ordered some screws. I appreciate the help!
As for the steering, I don't think it is the servo saver, because even with it tightened all the way down, it doesn't want to turn, and my servo horn broke because it pushed so hard but wasn't able to move anything. By hand it seems to turn OK when disconnected from the servo, but maybe I am just not sure how it should feel. I am quickly getting used to how easily everything seems to work on my Lightning.
aldwardo is offline
Old 07-24-2009, 07:38 AM
  #1500
aldwardo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ordered 100 of 2 of the types of screws linked above, and they shipped very quickly, unfortunately they are all too long. Thread size is right though, so I guess I just need to keep looking. If anyone needs $13 worth of m3 screws and washers let me know.
Edit: placed another order for 8mm length. The ones I ordered previously were all 12mm.
aldwardo is offline
