Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Hurricane Thread
Reply
Old 03-03-2008, 09:30 PM
  #151
papax5p
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Hurricane Thread
Also check the connectors to the receiver. Mine was the steering servo that was loose and lost steering.
papax5p is offline
Old 03-03-2008, 09:33 PM
  #152
papax5p
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The receiver batteries are going to go before the transmitter batteries. I have a hump pack coming for mine. Mine son has a tornado and his did the same thing. It was the batteries.
papax5p is offline
Old 03-03-2008, 09:36 PM
  #153
firebird78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
always check batteries, connections and also make sure ur crystals are pushed in..also check ur reciever antanna.....most likely u got a bad connection or weak batteries
firebird78 is offline
Old 03-03-2008, 09:42 PM
  #154
need2drag
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a similar problem with my Monsoon. I pushed all he connections together, and none of them seemed loose, but when I tried my car again, it was working fine. It could just be ever so slightly loose to where you can't tell, but it is. Push everything together and then test it without running the car, and see if that works.
need2drag is offline
Old 03-05-2008, 02:48 PM
  #155
usalien
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the Hurricane XL the same as the ExceedRC Razor? And are all the parts compatible?
usalien is offline
Old 03-05-2008, 02:54 PM
  #156
Macanan
Macanan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes they should be
Macanan is offline
Old 03-05-2008, 06:36 PM
  #157
firebird78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: usalien
yeah if you could still buy a hurricane xl...just xp or xp pro's now...diff being in the engine and radio..all other parts should fit
Old 04-07-2008, 10:55 PM
  #158
deschampzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can anyone tell me the factory carb settings for the hurricane xp sh 28. Thanks.
deschampzz is offline
Old 04-08-2008, 12:16 AM
  #159
mrlee2071
mrlee2071's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I set mine, LSN at 3 and HSN at 2 1/4 and tuned from there . May be a little rich but you can adjust.
mrlee2071 is offline
Old 04-08-2008, 12:23 AM
  #160
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcuniverse.com/forum/m_5399029/tm.htm
Swamp3r is offline
Old 04-08-2008, 10:54 AM
  #161
deschampzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am a newbie here and have a hurricane xp with the sh .28 motor. I am looking for the factory carb settings for the break in period the settings are all off and I want to start from scratch can someone tell me in a bit of detail. I know where all the needles are and what does what I just want to know the turns of them. THANKS.
Old 04-08-2008, 06:00 PM
  #162
firebird78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
put your idle at 1mm open....your high should be between 2 1/2 to 3 turn from all the way in (dont tighten tight)....low spd about 3 turns from all the way in (once again dont tighten tight)....this should get u runnin...just try to get around 200 asap..but prolly not much higher until ur done breaking in..and run a bit rich until ur done breaking in...dont forget to mark your flywheel were ur piston is at bdc...and ya always wanna put ur piston at bdc ASAP when ur engine is not runnin
Old 04-09-2008, 01:20 AM
  #163
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question why do you want the piston bdc when not running, is it just so the after run oil gets everywhere?
Swamp3r is offline
Old 04-09-2008, 06:48 AM
  #164
TThib
TThib's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Swamp3r
When the sleeve gets hot it expands (You will notice the flywheel is easier to turn). When the sleeve cools it contracts (gets tighter). If the piston is on the top stroke when the sleeve contracts, it can't contract to it's true size. Thus causing unnecessary wear and/or damage to your piston/sleeve.
TThib is offline
Old 04-09-2008, 08:57 AM
  #165
deschampzz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This car is making me so frustrated!!!!! I have followed your factory settings and I can get it up and running with some tweaking but when I hit the gas it bogs out! I have experience with bigger carbs but these ones seem so touchy mm off and they wont work....What do you recommend from scratch starting with settings and then troubleshooting for the bog....If I ease the gas VERY slow it wont stall but doesnt run very well...I still need to break this buggy in its brand new. Thanks for who ever helps!
Old 04-09-2008, 06:34 PM
  #166
Redcat Nick
Redcat Nick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Low speed needle sounds to rich. lean it out about 1/4 turn clockwise
Redcat Nick is offline
Old 04-09-2008, 07:06 PM
  #167
firebird78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Swamp3r
this is very important...if you dont put ur piston at bdc you can take out the pinch in your sleeve....you also want to get to operating temps as quick as possible...engine wears faster at low temps...u should try to get to or above 200 deg asap....trust me on these 2 things..I learned the hard way..lol
Old 04-09-2008, 08:51 PM
  #168
mrlee2071
mrlee2071's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey bro,
if the engine is too cold (just started) it will have a tendency to stall off idle. Make sure you let the engine warm up a little before you hit the throttle.
Remember, these are not regular engines, make very small adjustments at one time, one needle at a time. If it gets worse, start from where you were before you adjusted it and go the other way. When I say small adjustments, I mean no more than 1/8th of a turn.
It may take you some time (it did me) but when you finally get dialed in it will be a happy day
Oh yeah, make sure the pinch bolt (it's what holds the carb in, it's on the engine block below the carb) is tight. This is an area that can cause a lean condition.
Lee
Old 04-09-2008, 09:27 PM
  #169
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That makes alot of sense thanx guys
Swamp3r is offline
Old 04-09-2008, 10:39 PM
  #170
mrlee2071
mrlee2071's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Us newbies have to stick together bro
Old 04-23-2008, 09:58 PM
  #171
impune
impune's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i purchased a left over i'm guessing hurricane lx. with the.21 engine. my questions are as follows
there is a missing screw underneath, third in from underneath that is located going through a mount for the gas tank. what part number would that be? could not locate it in the box, and can see straight through the whole.
2nd question, there are different remotes/radios to these vehicles? the lx i received does not match the one in the redcat manual, but operates the truck with batteries added.
3rd, is the humm from the servo going to fade or break in? i don't recall my other ones humming. seems to disapear with steering then humm reappears. i tried to adjust the controller but seems to come back. i have not run the engine yet.
4thm what at the two metal beads with the grub screws suppose to be set or just remain loose sliding back and forth on the two arms that connect the breaks and throttle servo?
ID:	935727   Click image for larger version
ID:	935728   Click image for larger version
ID:	935729   Click image for larger version
ID:	935730   Click image for larger version
impune is offline
Old 04-23-2008, 10:11 PM
  #172
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also have the hurricane xl
1 Theres no screw that goes there
2 you can use any radio and receiver you want
3 All 3 of my trucks do that the hum, I can get my monsoon to stop once in awhile with the throttle trim but it usually starts again after a run.
4 Thats the way mine is and it operates just fine.
I'm still learning so if I'm wrong guys please step in.
Swamp3r is offline
Old 04-23-2008, 10:12 PM
  #173
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The metal beads with grub screws are adjusters for your brakes. You turn them and tighten or loosen your brakes. That hole is just for fuel to drain out of from the top of your fuel tank if you overfill. No screw goes there.
vnmsgt is offline
Old 04-23-2008, 10:16 PM
  #174
impune
impune's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does the remote look familiar to the lx model anyone received too?
also the grub scews should be set in a specific way? rolling the brakes seem to work. i am waiting for a day to play. in day ten staight at work. trying to get myself to bed, but intriqued to learn.
thank you very much.
impune is offline
Old 04-23-2008, 10:17 PM
  #175
mrlee2071
mrlee2071's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good day mate,
I'll try to answer your questions, in order.
1st - the hole in the bottom is not a missing screw, it's where the allignment peg/overflow drain (hole for the fuel tank) is located to the chassie
2nd - Yes there are different radios. Redcat has recalled FM radios, yours apperes to be an AM radio. Also it depends on how long ago your hurricane was made. Could be that earlier versions came with the radio you have. My brother has just purchaced a new Hurricane XP, it came with the same radio you have. He has had no problems with it.
3rd - Make sure the antenna is all the way up on the transmitter and not right next to the car. This may or may not affect the servos.
4th - The silver collars - I have no idea what they are for, but, but, but you don not want them sliding around on the linkage. they might get caught up on something and jam the throttle linkage. Mine are located about 1/4 inch from the servo connectors.
Hope this helps.
Lee
Reply
Display Modes
