Redcat Racing Tornado Thread
#2777
KY
RE: Redcat Racing Tornado Thread
wait i might be naming the thing that fell off wrong...its a very big dogbone that goes in the cups that go in the gearboxes that turn the wheels...the ones closest to all 4 wheels. are the called drive shafts?
#2778
KY
does this fit the vx .18 carb opening? [link=http://www.nitrodeals.com/catalog/index.php?main_page=product_info&cPath=1&products_id=47&zenid=04733640b2e2f54af6175ad89465f331]alu. air filter[/link]
#2779
CA
Almost all 1/10 air filters are the same.............................and as for the dog bonz you will have to ask around or search down the procedure that I'm talking about. Its a little O ring that comes with it originally but a small slice of fuel line works the same way and much cheaper. Dog Bonz = Drive shafts [:-]
#2780
KS
Guys this is crazy. the lower cap on the body of the shocks that holds the o-rings in is somehow threaded wrong and on three of my shocks all of the shock oil is falling out. have any of you had this problem?
#2782
KY
ORIGINAL: rcphanatik
#2784
KS
hey, also what gear ratio should be used with a set of 4, 2.8 inch rims on the stock engine-my stock tires are obviously wearing down WAY too fast on the road.
I'm happy, my car ran pretty well today even with the shock oil dripping out!
#2785
KY
bob, do i need to buy new ones? seriously, i thought they would hold up better.
#2788
anyone know which NiCd battery can go in the tornado so that i don't have to keep replacing batteries to power the servo and reciever?
#2789
I am new to RC cars. I have a Tornado XP and the pull start broke. The string came all the way out. On Redcats site they have a few different replacement parts. How do I know which to purchase? Are there any options to replace the pull start with another starting mechanism?
Thank you.
Thank you.
#2790
KS
you can either get the stock pull start unit which should have a redcat product number in the manual, or an upgraded rotostart unit. i am not sure which rotostart to get because i have not upgraded mine with that yet.
hey, i just had a huge problem with my rear gearbox on the bb-the car is currently front wheel drive. do i have to take the whole thing apart just to see which part broke-it looks really complicated.[]
#2791
#2792
ORIGINAL: stagga
#2793
#2794
ORIGINAL: gokartingbob455
yeah i thought they would hold up better to but thats what you get for Chinese crap. im gonna fill the shock again one more time and see if the caps still fall off. then im gonna get new shocks. i'd suggest you do the same.
#2795
ORIGINAL: Hibityhupla!
if you look under receiver battery in ebay you should find some. It's a 6v 5 cell hump pack i believe.
ORIGINAL: stagga
#2796
ORIGINAL: stagga
OK thanks. Do you know if our cars use a J connection or universal? Or does it even matter? lol
ORIGINAL: stagga
#2797
KS
thanks dude, i was afraid i would have to take it all apart...that really would have stunk 'cause i probably would have lost a piece.
#2798
KS
about the 2.8 tires, i was thinking that maybe like an electric motor, the engine would overheat-but i take it that's a no, that's good cause i wanted to see how fast this baby would go.
#2799
KS
hey, i just got another problem.[:@] this is the first day i ran the tornado bb through the dirt, and something is binding up. it isn't the center drivetrain, it is single wheels locking up on their own. anybody have any ideas? i think dirt may have gotten into the gearbox-but as i said before, i don't really want to take that apart.[]
#2800
The worst that would happen if rocks made it inside the diff is it would chew the gears or lock like a one-way. There really isn't a way for dirt to get in there though. Are they binding at the drive cups? Rocks in between the wheels and hubs? Another thing I had happen to me was the tranny lost one tooth and would lock up after 5ft if that. Binding dogbones can be fixed by loosening the shocks or screwing in the allen screw on the arms that adjusts height. Doesn't really sound like a diff. problem though. Try to trouble shoot it from the clutch bell out. Let me know what you find...
