Redcat Racing Tornado Thread
#3376
NJ
When it came time for me to buy a buggy I went with the single speed because I read that the two-speeds have nothing but problems. Plus where I'm running, I really dont have room for 2nd gear to kick in anyway. But good luck and let me know how you make out. Later, Joe
#3377
alright i have had a tornado bb for about 2 months, i have 3 glow plugs and was wondering if anyone knew how to tell them apart? i realize they are stamped on the side of the plug itself but the labels dont show anything. i am new the hobby and havent found out how to tell the difference between them. i know i ordered a cold, med and hot. just need to know which one is which? thanks
#3378
NJ
Are there different color rings around the top of the plug? If so what are they?
#3379
MN
i was running my car today and when i would tap the throttle it would seem like the servo wasnt returning all the way back but it was and after a while it would go back to idling again. the car had been almost completely under water but i got most of the water out and it runs alright except for that
#3380
My 2 speed transmission on my tornado bb has stripped out two times since getting it in February. I believe this time it was my second speed spur gear since it wont shift into second and bogs out at anything above minimum throttle. Are there any better quality spur gears that will fit my tonado bb 1/10 scale and not strip as easily? thank you. If not is it the 44 t, 39 t, 58 t, 47 t, or 42 t, spur gear that needs replacing. Thanks
#3381
AZ
Dude if i were you i would just get the direct drive transmission. 2 speeds are really only good for going straight
#3382
MN
is my lsn running to rich
#3383
no different color rings but one is stamped n3 on the side of the plug itself, another one is r3. no colors on the plugs at all. thanks for replying
#3384
#3385
have you watched the video one redcat racing support about setting the gear mesh for your spur gear? i know if you don't have it set it right the gears will strip pretty easy.
#3386
these could be helpful to prevent the stripping from occurring, however, right now i need the question above to be answered.
#3387
i have a tornado bb and i have been wanting for some time now to upgrade the engine. i was just wondering what engine would provide the most acceleration but would also be a direct fit? Also i was wondering if anyone knew of any good sites to buy hop up parts from. Thanks!
#3388
AZ
The sh 18 engine is a good upgrade, really good engine. With the redcats engine replacement program you can get it for 45 bucks which is a awesome deal. The os cr-vs (i think thats the one) motor is even better, buty thats like 120 bucks or something. Get the sh, you will be happy with it
#3389
Is it really that much of an upgrade though?
#3390
AZ
Oh ya, you would be suprised. Just because the engine is the same displacement, doesnt mean that it puts out the same power. I would deffinitely reccomend the sh 18
#3391
hey guys, i got cameron at redcat to tell me how to tell the glow plugs apart. i now have a new problem, i have a hard time starting the engine, when it does start it wants to scream at sounds like full throttle, wont idle at all, not even close to where the idle needs to be. the tires are screaming fast. i have tried setting the needles back to original factory settings, i took off the carb and cleaned all the internal pieces(fully disassembled), i am running a medium glow plug and 20% nitro. fairly new to the nitro world. i am about to take the shotgun to the dam thing but i still have hope. please help.
#3392
MN
will it start on the ground? ur clutch spring might be shot. try rolling the car on the ground see if it is catching at all
#3393
just went and triedd rolling it on the ground. almost no resistance. rolls all the way across my basement floor with very minimal effort. no catching or binding anywhere.
#3394
i cant try to start it on the ground right now, there are some kids sleeping in the house. i was messin with it earlier today and when it did start it ran for only a few seconds and when it was running it wanted ta run 1000 miles an hour. it did run for more than a couple seconds a couple of times but i had to keep it running with the throttle.
#3395
MN
when u had the engine running did it sound like the idle was set really high or were just the wheels spinning fast
#3396
it was running really fast (engine). tirea were screamin too but they should have been. i cant get the idle to come down and stabalize, it just dies. now i have set the gap in the carb to about 1mm, reset the carb to the factory settings and i removes disassembled and cleaned the carb. i have a medium glow plug with one tank of 20% fuel ran through it. my glow igniter is fully charged, i have blew through both fuel lines and they are clear. the only thing i can think of left is the clutch spring but it isn't showing any symptoms of that being the problem
#3397
MN
what did u set high speed needle at?
#3398
2 1/2 turns out on both. thats what it says to do oin the manual, thats what it was when i got it. only after i changed glow plugs and started messin with the needles did this happen, and the screw for the brake linkage fell out so is got another one. i have checked the throttle linkage to see if it is binding and have found nothing, thanks by the way for helping.
#3399
MN
the stock setting on mine was at 3 turns out on the hsn and flush with the lsn
if that helps u any
if that helps u any
#3400
MN
check the idle gap with the controller and reciever on. ur throttle trim on ur controller might be sett high
