Redcat Racing Tornado Thread
#451
NJ
RE: Redcat Racing Tornado Thread
Yep. Here is my shockwave with the HPI header and stock muffler on..
ORIGINAL: shadowscion
Will
Associated Muffler RPM Tuned Side Exhaust - $18.39 -------------- http://www2.towerhobbies.com/cgi-bin...?&I=LXBMH0&P=7
HPI Aluminum Exhaust Header Nitro 3 - $12.99 -------------- http://www2.towerhobbies.com/cgi-bin...&I=LXBTB5&P=ML
fit on a Tornado XL(shockwave)?
Will
#452
Cool thanks.
Nice picture mate, I haven't been able to find a picture of a close up of the shockwave, thanks
Edit>
So I'm getting the shockwave for my birthday and before I even run it I'm going to do the mods...
Car:
TORNADO XL - $99.99 -------------- http://www.redcatracing.com/itemdeta...partno=TORNADO
Nitro Starter Kit And RC Tool Set - $19.99 -------------- http://www.clermontmotorsports.com/s...ter-Kit/Detail
Traxxas Top Fuel 20% Quart - $8.99 -------------- http://www2.towerhobbies.com/cgi-bin...&I=LXJM38&P=ML
Upgrades(Needed):
Hpi 17 Tooth Vented Clutchbell - $14.99 -------------- http://www.clermontmotorsports.com/s...-vented/Detail
Traxxas Clutch Shoes/Spring T-Maxx - $7.39 -------------- http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Extras:
So all of that will get me running good for under $200 I guess. I could probably talk them into getting me the car,starter kit and fuel for me. Then I would enough money for the the clutchbell and spring at that time, then once I get paid for painting a garage I could get the pipe and anything else. Is anything else needed?
Edit>
Car:
Upgrades(Needed):
Extras:
#453
you should be good with that bro, you dont really need the clutch bell and spring, it should come with a steel one and better spring and shoes.
#459
I ran into the first problem w/ my Tornado today. The throttle servo isn't working correctly...the servo only opens the carb ~1/2 of the way and sometimes gets stuck there. When applying the brake the servo makes a loud grinding/ticking noise and doesn't move the rod at all.
When I broke the car in I noticed that the spring on the servo rod was sort of warped, but the servo worked fine. I tried adjusting the grub screw at the end of the spring, but that made things worse. Is the spring the problem, or do I have a bad servo? And what parts would be available at the LHS?
I can post pics if it will narrow the problem down.
#460
take the stock steering servo and move it to the throttal and use this for steering
http://www2.towerhobbies.com/cgi-bin...&I=LXDWF8&P=RF
there are cheaper options but this one works great. btw the stockers are crap and anything futaba or hitech is an improvement.
#461
NJ
Yes sounds like the servo went away. Mine actually came apart while installing on the new aluminum upper plate.. So I replaced it with a Hi tec servo I had laying around. Works good.
ORIGINAL: wheatstraw
#464
ORIGINAL: FlyinGN
Also, would the LHS have a replacement spring or something comparable for the throttle? I can't seem to find a replacement on Redcat's site. Thanks guys.
#466
NJ
Could you guys identify my buggy? Someone said it could be a Redcat
http://www.rcuniverse.com/forum/m_59...tm.htm#5936489
I'll have much better pics soon.
#469
NY
It is not a redcat because the redcats only have 1 a-arm on each side and the tank is different. Here are some pictures of a redcat. It is all stock except for the clutch bell, exahust pipe and [&:]tires.
#470
NY
On the redcat tornado thread it says that it is by author clermont motor sports. How can I make a thread like this one(redcat racing tornado thread)[sm=omg_smile.gif]
#475
ORIGINAL: spartan8892
can you post pics on how to replace the clutch bell and spring plaese thanks
