Redcat Racing Tornado Thread
#1026
RE: Redcat Racing Tornado Thread
Hey guys, thanks for all your help,
could you tell me if this will fit my tornado bb?
HPI NITRO MT2 MT 2 18SS+ Header+Black Coupler HM22
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=001
#1028
ORIGINAL: newdoughboy
#1031
FL
sorry for having to ask but i,m about to replace the clutch and spring before i order the redcat one, is there something thats better than the stock redcat clutchbell and stock redcat spring and shoes??? if so where could i get them??? i am trying to get my tornado running agin i,m also replacing the servos cause there shot but i,m just wandering if its worth spending more money for nicer clutch components...[sm=shades_smile.gif]
#1035
FL
nuther question i am trying to start my tornado but without a clutch spring i don,t think its possible it will start for a secont spin the wheels real fast and die is that just due to the clutch problem????
#1036
It is possible to make it start with a broke clutch if all the tires are off the ground. You can run it like that but you will have to stay moving constantly. The second you stop the car will die.
#1037
FL
well should i have the throttle open all the way cause it will start but then it dies!!! i think its having a problem start due to constantly being engaged i mean imagine a real car being started in gear.... nuther problem im working with a rather crappy pull start i think thats another problem everytime the car wants to fire up the pull start dosen,t want to retract!!! could this be a problem???
#1038
got bored today and wanted to do something, so i made a little something for my antenna,
it still needs to be wetsanded and polsihed so itll all be one color, and than i also made a
new post for my old fly wheel, since the 1 post was broken off.. what you guys think, and
what you think the antenna post thing is made of
#1040
ORIGINAL: blakeyboy250
Pull your clutch bell off and check your clutch. If it's bad it will need to be replaced or you'll continue to have problems until you do.
#1042
I think it looks just like a bullet
Hey guys, so I bought a hpi mt2 al header and exhaust for my bb and firestorm tires, I can't wait for them to come in. I was wondering if you guys could just start throwing in some ideas for hop-ups, say under $30. Thanks
#1043
ORIGINAL: hibityhupla
almost looks like the end of a pen or a bullet.
#1044
fuel filter, extra shocks, spare dogbones, aluminum tie rods, hpi threaded clutch bell and gears, spare tranny gears, fail safe, spare glow plugs, roto-start, new electronics.
#1046
pretty good idea with the pen tip. I'll have to try that.
#1047
yeah I have a bunch of scars from not thinking before working. My last one was good. I was carving a car out of wood with a chisel and slipped and stuck it through the skin in between your first finger and thumb. THAT SUCKED! I opened my hand to see what i did and my thumb kept going.
#1048
Thanks, I was wondering what brand of roto starter will fit the vx-18 and what back plate. Are there third party dogbones that will fit the tornado? and, what difference do you get when you change the # of teeth on the clutch bell? is a new clutch bell necessary even if mine is working fine? I know that having spare parts are great. Does the pinion gears need lock tight? i know it's a difference of 5 between 2nd and 1st gear. Thanks for the help guys
#1049
I got my roto-start from redcatracing.com. I tried a bunch of dogbones and the 06022 work the best. The gearing will change the speed smaller for more torque larger for more top end. It isn't necessary to change the bell right away. If you have the steel one I hear it's fine but the stock aluminum one sucks.
#1050
